I did a search earlier (honestly!) but when you use the words "PartsExpress", "subwoofer" and "12"" you wouldn't believe the amount of non-related threads that come up!
I think it would be cool if PE sold matching speakers to go along with their two budget subs, using the same design/pricing philosophy. Say, two-ways with one model equipped with a 4" midwoofer and a step-up model for large rooms equipped with a 6.5" woofer.
Because I have a feeling with the way the economy will (probably) be doing in the coming months, more and more people will be spending more time at home but at the same time, won't have as much money to divert to their HT system.
Those DIY BR-1 jobs would qualify. Actually they have more than a few speakers for sale. When you're broke, the first thing that goes is the need for a matching anything, like socks.
"I'm broke, but I gots matching Spekers for my Subwoffer!"
I agree that two of these, stacked and eq'd should really pack some punch. So what if you have to give up a few db's under say, 25hz - Impact should be there in spades.
Funny - just when I think I'm out of money, another box is waiting on my front step.
The only problem, and the only reason why I didn't buy a pair just to try out, is their extremely low sensitivity of 85dB, and the fact that they roll off at about 18kHz. Has anyone heard these guys?
I just watched The Incredibles with this sub. It did a good job of getting me several "that's way too much" looks from my wife. How much break in does a sub typically need? Over the past month I've put several hours (6-8) into watching the LOTR series and it is beginning to sound better.
The change will take place gradually over 100 hours or so. My SVS got a bit louder over the first month - Started out calibrated at -5, eventually had to rebuild the gain chain as the speaker broke in. (Calibrated every week or so and eventually got to -10 on the AVR. Brought it to -5 again and dropped the level on the amp.)
If you don't mind doing a little assembly work some of the Dayton kits look to be real winners. I haven't heard any of them yet, but I have built a few speakers using their aluminum cone 5.25" and 7" woofers and a Vifa tweeter. I was quite impressed with them. PE is getting good at giving you a lot for your money. The new Dayton RS series drivers are just an absolute steal for the performance you get. Can't wait to get my big 3-way towers done!
