Jump to content
How Do Digital Receivers (like HK 2005) Handle 4 Ohm Loads? More Power into 4 Ohms?
  • Please log in to reply
2 replies to this topic
#1 of 3 OFFLINE   Arthur S
Arthur S
  • 2,572 posts
Posted August 25 2005 - 09:39 AM
I get the impression that digital receivers do not handle 4 ohm loads as easily as analog receivers. Some think that digital can acutally put out more power with all channels driven into 4 ohms using ordinary digital receivers. What about this? Thanks
#2 of 3 OFFLINE   Justin_D
Justin_D
  • 217 posts
Posted August 25 2005 - 12:35 PM
I'm speaking just from that Panasonic point of view (XR25/45/50/55/70 line). It is true that they can HANDLE them, but not very well. TI's documents of their chip (the heart to the Panny and some other lines) show that the high frequencies roll off as more power is pumped into a lower impedance speaker, which defeats the whole purpose of a digital receiver all together doesn't it? If your speakers dip into or below the 4-ohm area, IMHO, you should either wait until digital amps are a bit more developed for consumer use, or look at analog amps (I would wait judging by the Panny receivers quality/price ratio, there is only more to follow). Good luck.
#3 of 3 OFFLINE   FeisalK
FeisalK
  • 1,245 posts
Posted August 26 2005 - 01:43 AM
Rotel seems to have hit on a solution apparently with the 1077 a 7x100w power amp...
Posted Image
follow the discussion at HTguide's Club Rotel
DVD-A registry for hirez/surround audio
Bluray, DVD-Audio, DAD/HDAD, DualDisc, MVI
