Need a little help setting up my 4805 with Onkyo 770 & DVD please (1 Viewer)
Frank_D
I had a tech explain it to me but I think he has it a little wrong.
This is what I have so far and everything works but I am having trouble adding the dvd?
Time Warner HD box -> (component) to Onkyo receiver
Onkyo Receiver -> (component) to Infocus projector
I was told to run the dvd with an s video or composite but I am thinking I should run it with a component cable.
Can anyone tell me how to hook up the dvd player to the Onkyo so I can get a good picture AND full 5.1 sound?
Thanks!
John S
yep.. DVD Player using component also to the AVR. Optical to the AVR for sound.
If you have a progressive scan DVD player, try it with Progressive and straight 480i out the component video if you player allows it.
I see no reason to fall back to svideo and/or composite.
Frank_D
Okay, thanks John.
I'll get a component cable and a digital cable today and run them both from the dvd to the receiver.
Sounds easy but I will find a way to screw it up. :)
Kevin Deacon
Yor solution is much nicer that what I have. The only switching between sources you will need to do is with the Onkyo receiver.
My DVD only has S-video so I have to switch both the receiver and my 4805.
Have you had the 4805 long? What an awesome PJ for the price.
I've had mine since December 2004.
Frank_D
I got it a couple months ago but just got it hooked up to HD channels. Yes, the picture is awesome!
Now I just need to get the DVD player hooked up with some sound for some movies.
blitz
