Jump to content
PSP and Memory Stick Pro Duo
  • Please log in to reply
24 replies to this topic
#1 of 25 OFFLINE   Anthony Hom
Anthony Hom
  • 893 posts
Posted May 03 2005 - 04:12 AM
Anyone here use Pro sticks instead of standard Duo? It says in the manual that MP3 and ATRAC will only play on Memory Stick Duo and not Pro Duo. Can anyone verify this to be true? It's in the PSP manual but wondered if anyone actually tried to play MP3s on a Pro Duo stick.
#2 of 25 OFFLINE   MikeMeehan
MikeMeehan
  • 51 posts
Posted May 03 2005 - 01:55 PM
I use a sandisk pro duo for mp3 on my psp with no problems. buy.com has a good price on them (when they have em).
#3 of 25 OFFLINE   Anthony Hom
Anthony Hom
  • 893 posts
Posted May 04 2005 - 06:49 AM
Thanks! Plus, do you recommend formatting them with the PSP utility before using them?
#4 of 25 OFFLINE   MikeMeehan
MikeMeehan
  • 51 posts
Posted May 04 2005 - 01:51 PM
You don't need to format mp3 files only video files.Some of my mp3 files are five years old and i just drag and drop them into the music folder.anything else, just ask.
#5 of 25 OFFLINE   Anthony Hom
Anthony Hom
  • 893 posts
Posted May 05 2005 - 10:17 AM
I seem to be having a pr;oblem with playing MP3. I put the MP3 files into the MUSIC folder which is in the PSP folder. when I'm in the system menu, I chose the music icon, and see a list of numbers plus the mp3 designation. but when i click on the X to start, the system just locks up and I have to restart. It plays games just fine, I haven't done any MPEG4 videos yet.
#6 of 25 OFFLINE   MikeMeehan
MikeMeehan
  • 51 posts
Posted May 06 2005 - 08:03 AM
That's weird.I would re-format your memory stick.Make sure you to copy any game saves to your computer before formatting.
#7 of 25 OFFLINE   TedT
TedT
  • 422 posts
Posted May 13 2005 - 05:22 AM
So will PRO sticks work? With mp4 movies? Going on a big trip next week and Fry's has a sale on the 1gig PRO (not DUO) sticks.
#8 of 25 OFFLINE   PeterTHX
PeterTHX
  • 2,034 posts
Posted May 13 2005 - 05:36 AM
Pro will work fine. Matter of fact PRO is much better to use than standard. Faster (think USB 1.1 vs. 2.0) Anything more than 128MB will be PRO, no matter what: std only supported 1 128MB bank, the old 256 standard actually had a switch for 2 128MB banks. PSP and any Sony device 2003+ supports PRO. If it doesn't support anything it's the MAGIC GATE which is the onboard encryption (optional).
#9 of 25 OFFLINE   TedT
TedT
  • 422 posts
Posted May 13 2005 - 05:42 AM
I just didn't know if PRO or PRO DUO are the ones to use w/ the PSP. Cool. I'll try out a PRO then. thanks.
#10 of 25 OFFLINE   TonyTone
TonyTone
  • 728 posts
Posted May 16 2005 - 06:38 AM
Don't you mean "Memory Stick Duo"? I mean, I could be wrong but I can't see how it would be physically possible to insert a MS Pro stick into the PSP memory stick slot w/o either damaging the stick, the slot, or both... FWIW--the two kinds of memory sticks that will fit in the PSP slot are MS Duo and MS Pro Duo...but since it appears Sony doesn't currently offer many different sizes of MS Duo sticks (the only one they list on their website in the MS Duo flavor is 128 MB), you're basically left w/ the MS Pro Duo, which of course is currently difficult to find in the 1 GB size. There is an adapter which will allow you to insert either one into an MS Pro slot, but an MS Pro stick (or MS Pro adapter) itself will not fit into the PSP media card slot.
#11 of 25 OFFLINE   ClintS
ClintS
  • 169 posts
Posted May 16 2005 - 09:32 AM
OP The Pro DUOS's will work fine for everything except ATRAC3 files. The PRO Duo's will NOT work with the Sony Connect software even though they say MagicGate. Everything else is exactly the same including the transfer speeds both are USB2.0 speed compliant (regular duo's and duo pro's). MP3's will play fine and so will MPG4 video.
#12 of 25 OFFLINE   Anthony Hom
Anthony Hom
  • 893 posts
Posted May 16 2005 - 10:23 AM
the Duo type according to the book depends on your use of ATRACs. They need magic gate sticks. I have used Pro Duo and it seems to work, except for my flaky MP3 files. Is everyone here just using 128k Mp3s, or are you using higher like 192 and 256? The MP4 videos are working just fine.
#13 of 25 OFFLINE   TedT
TedT
  • 422 posts
Posted May 16 2005 - 11:21 AM
Thanks TonyTone. Yeah, I meant PRO vs PRO DUO. You answered my question. Thanks.
#14 of 25 OFFLINE   ClintS
ClintS
  • 169 posts
Posted May 17 2005 - 01:48 AM
The MP3's I have played have been all over the map from 96kp and up, they all play fine on the PSP. I really wish the Duo Pro's worked with ATRAC3 format as it sounds superior sound quality wise with smaller file size. But even content you load from CD's in the Sony Connect Software to ATRAC3 will not transfer to the PRO Duo's only the lower capacity normal Duo's. So I gave up and went back to using MP3 I usually encode at 160kbps which is the best for me considering sound quality and file size.
#15 of 25 OFFLINE   Jean D
Jean D
  • 1,329 posts
Posted May 18 2005 - 03:27 AM
Hey guys, im having a really hard time finding the 1gb yellow Sandisc Memory Stick PRO Duo (Or ANY 1gb duo pro for that matter). Everywhere is backordered and they keep pushing the dates back further and further. Im getting annoyed with this, I bought my PSP last week hoping Id be able to actually use it for more than just games. If I'd have known there was a demand for these cards, I would have held out on the PSP. Anyone know where I could get one and not spend over $120 (with shipping)? I really dont want to buy a smaller one, just to buy a larger one months from now, and I dont want to pay a premium price for one either. Do I have any other options?
Gear: Crestron AADS, Crestron 4L, RTI T2C, SVS PC 16-46, Xbox 360, Wii, Bass Shakers, TiVo HD, Toshiba A3 HD-DVD, 42" Panasonic TH-42PWD8UK, two Denon AVR-2106's, Speaker Craft Aim 7 Five's, Samsung HD-950 DVD player.
#16 of 25 OFFLINE   Ken Chui
Ken Chui
  • 976 posts
Posted May 18 2005 - 07:24 AM
Jean:
PC Connection has both the SanDisk and Sony 1GB PRO Duo cards on order (SanDisk cards should be available in 1-2 weeks, Sony 2 weeks+). The SanDisk is retailing for $105.95 (+ S/H) and the Sony for $92.95.
The problem with discounted sightings is that this info is picked up quickly by gaming and bargain hunter forums, and sell-through of stock can happen in a matter of minutes. Given the immense popularity of the 1GB card and low inventories, I expect prices to remain relatively high at smaller, independent e-tailers; the heavyweights (Amazon, Newegg, etc.) may be more affordable, but you'll need to check these sites frequently to ensure your chances of securing one.
#17 of 25 OFFLINE   Jean D
Jean D
  • 1,329 posts
Posted May 18 2005 - 07:29 AM
Thanks Ken. I just took the plung with Ebay however. the 1gb sony one. winning bid @ $131.00 and $144 with shipping and insurance. Ouch. I just couldnt wait. I have a few hour car trip comming up next weekend and I really wanted one. Oh well.
#18 of 25 OFFLINE   Ken Chui
Ken Chui
  • 976 posts
Posted June 12 2005 - 02:22 AM
eCost has Sandisk 1 GB Memory Stick Pro DUO cards in stock for $99.99 (21 units still available as of this posting); I just ordered one myself. Here's the link:
http://www.ecost.com....pno~651408.asp
#19 of 25 OFFLINE   Leo
Leo
  • 293 posts
Posted June 13 2005 - 11:30 AM
Yeah, the memory stick pro duo is a challenge to find in stock. What I normally do is go to BHPhoto.com and submit my email for notification when they get them in stock. I got a notification yesterday from them and ordered one. It's scheduled to ship on Wednesday. They're marked as sold out now.
#20 of 25 OFFLINE   DaveF
DaveF
  • 15,373 posts
  • Real Name:David Fischer
  • LocationOne Loudoun, Ashburn, VA
Posted June 14 2005 - 08:15 AM
I can't speak for the Duo, but the SanDisk 1GB Pro is available through NewEgg for about $100 shipped -- I just bought one for my digital camera. The Sony MS Pro 1GB is sporadically available from Amazon for about $100 good price.
