Jump to content
Sign up for a free account!
need help with box finish...
1 reply to this topic
#1 of 2 BryanDO
BryanDO
  • 111 posts
Posted April 25 2005 - 02:14 AM
Hey guys, I have kind of a weird situation here. I completed my sub, had a vinyl finish on it. I then noticed an air leak at one of the joints so the vinyl had to come off. Now the box is raw MDF, but, theres 3m glue and pieces of cotton all over the box. Is there a way to take it off? I want to go with a dark wood finish like many of you guys and commercial subs have. How would
I do that in my situation? Thanks a million.
P.S. This is kind of urgent because right now the ugly sub is inthe basement. Me and my girlfriend are moving and she says the sub can't go in the living room looking like it is! Need to make it attractive or my bass will be lost! Help Posted Image
#2 of 2 Stephen Hopkins
Stephen Hopkins
  • 2,598 posts
Posted April 25 2005 - 04:35 AM
I'd contact 3M and see what kind of solvent they reccomend. Once you get the glue/cotton off then you can easily cover in vinyl from parts express for an easy and inexpensive faux wood finish.
