Jump to content
Help Building Sub..
12 replies to this topic
#1 of 13 OFFLINE   MikeGee
MikeGee
  • 288 posts
Posted April 20 2005 - 02:10 AM
Hey guys
I need some advice here. I've been looking around on here for some helpful advice on building my own subwoofer.
I would be looking at getting a 12" driver. If anyone had any links, dimensions, wiring diagrams.. anything that can help me do this cause i'm fairly new to this.
I've seen alot of you guys have some pretty awesome home made speakers so your info would be appreciated.
I've been looking around and i really like the Sonotube design.. Any help with this design would be really appreciated.
#2 of 13 OFFLINE   Bob Kavanaugh
Bob Kavanaugh
  • 282 posts
Posted April 20 2005 - 03:16 AM
I've built 2 subs using Adire drivers and specs from their website. Like you, I wanted to build a sonotube sub, but I couldn't find any sonotube. Posted Image MDF, however, is the ubiquitous building material of our time.
Here's an example of what's out there...
Vented Tempest Applications
#3 of 13 OFFLINE   Dave Poehlman
Dave Poehlman
    Producer
  • 3,817 posts
Posted April 20 2005 - 09:47 AM
I've seen it at Home Depot or you could check your local concrete suppliers.
"Sonotube" is just a brand name for a heavy-duty form for pouring concrete footings. I would think any brand would work in its place.
#4 of 13 OFFLINE   MikeGee
MikeGee
  • 288 posts
Posted April 20 2005 - 10:38 AM
I can get my hands on Sonotube luckly. Any pages that you guys know of that describe in detail how to go about putting the whole thing together.
There is an electronics store near my house that sells all home audio parts so thats where all my pieces will come from. (I'll get to specifics on parts and brands once i get to the store tommorow)
I just need to really know some tips for putting it together. Especially the wiring the sub with the plate amp. Thanks again!
#5 of 13 OFFLINE   Patrick Sun
Patrick Sun
    Studio Mogul
  • 37,753 posts
Posted April 20 2005 - 10:42 AM
http://members.tripo....um/page12.html
"Jee-sus, it's like Iwo Jima out there" - Roger Sterling on "Mad Men"
Patcave | 2006 Films | 2007 Films | Flickr | Comic-Con 2012 | Dragon*Con 2012
#6 of 13 OFFLINE   Dave Poehlman
Dave Poehlman
    Producer
  • 3,817 posts
Posted April 20 2005 - 11:28 AM
That's the beauty of building a sub... it's no more difficult than hooking up a speaker to your receiver.
#7 of 13 OFFLINE   Stephen Hopkins
Stephen Hopkins
  • 2,598 posts
Posted April 20 2005 - 01:41 PM
If you want the absolute easiest way to build a sonosub then check this out...
http://www.creatives....l=EZTUBESHIVAP
$280 for all the materials, detailed directions, and driver to build a finished passive Shiva sonosub. For $20 more you can add the plate amp box kit that goes on the side. If you're looking at using a different driver then give them a call and they might be able to work a deal on the kit without the driver. That said, the Shiva is a great driver for mid sized rooms and ported enclosures. With this kit the only tool ya need is a hand-held screwdriver. It even includes a cloth sock that stretches over the entire sub and gives it a very professional finish. Check the assembly manual (linked in the product page) for specs, measurments, performance, and finished pictures.
#8 of 13 OFFLINE   Bob Kavanaugh
Bob Kavanaugh
  • 282 posts
Posted April 21 2005 - 03:01 AM
We just have the crappy thin forms at our Home Depot. Must be a regional thing.
What's crazy is that my dad tests concrete on jobsites, and I put him on the lookout for some sonotube, and even he has yet to find me any. Or maybe he's just holding out on me Posted Image
#9 of 13 OFFLINE   Dave Poehlman
Dave Poehlman
    Producer
  • 3,817 posts
Posted April 21 2005 - 04:18 AM
Well, actually I don't think Sonotube is much more than 1/4" thick. It gets its strength when you cap the ends.
#10 of 13 OFFLINE   Kyle Richardson
Kyle Richardson
  • 1,076 posts
Posted April 21 2005 - 05:52 AM
Most of the time you need to go to concrete specialty shops to get the larger diameter tubes needed for subwoofers.
Kyle Richardson
Acoustic Visions
AOL Instant Messenger Name: kyler70
MSN IM: acousticvisions@hotmail.com
#11 of 13 OFFLINE   MikeGee
MikeGee
  • 288 posts
Posted April 22 2005 - 11:52 AM
Ok thanks for the links. VERY VERY helpful.
Just a couple of quick questions..
(My setup will be a single 12")
1) Connecting the -/+ speaker wire coming off the terminal binding post to my receiver.. How does the end of that connection work with the kinda RCA type input for my subwoofer
2) Since i'm going to have a single 12" i'm going to put the port hole on the bottom and cap the top. When filling with the polyfil should i just glue it all around the inner part of the sonotube? or should it just be stuffed in. My guess is to keep the polyfill quite a bit away from the driver itself...
3) Got prices on the amp/driver at my local place. I can get a 250rms plate amp for 220$ Canadian however the driver seemed a bit crappy and is only 80$ (H/P Subwoofer which i've never heard of) Anything else i can't seem to find good prices shipped to canada especially without worrying about customs.
#12 of 13 OFFLINE   Dave Poehlman
Dave Poehlman
    Producer
  • 3,817 posts
Posted April 22 2005 - 01:16 PM
I have a downfiring sub albeit not a sonotube... but what I did was to use a piece of windowscreen stapled across the inside to support the fill off of the driver.
You definitely don't want the fill sitting on top of the driver.
#13 of 13 OFFLINE   Joey Skinner
Joey Skinner
  • 339 posts
Posted April 22 2005 - 03:14 PM
Your speaker +/- will connect to the 2 wires coming from the back of the plate amp. The amp should have RCA inputs on the front to connect to your receiver. You can just line the inside of the tube with egg crate foam like a mattress pad and not use any stuffing at all.
Back to Members' Theaters, HT Projects, Remotes, Seating, Accessories & Lighting
Forum Nav Content I Follow
