Jump to content
Problems playing discs w/ Toshiba player...
  • Please log in to reply
1 reply to this topic
#1 of 2 OFFLINE   Paul K.
Paul K.
  • 11 posts
Posted March 09 2005 - 07:55 AM
Hi, I have a Toshiba SD-K600 DVD player hooked up to my 27" (non-HD) TV. I got it free from someone not using it anymore, so I can't really complain too much, it plays commercial DVDs and Cds just fine, with DD and DTS decoding. The manual stated, and I have always found (until recently), that it will not play "burned" media (DVD or CD). Recently I've gotten engaged, and in the process of looking at samples from videographers I have discovered, much to my surprise, that the Toshiba WILL play SOME burned DVD discs; but not others. I have personally tried playing a DVD-R disc with no sucess (one that does play in other players). What's the trick to this thing? Might it only play DVD+R media? Some kind of option I need to select when making a DVD so that it will play? I've thought about replacing this player with one not so limited, but if there's an easy fix I might not have to...
-Paul
#2 of 2 OFFLINE   Randy C Sr
Randy C Sr
  • 51 posts
Posted March 09 2005 - 08:39 PM
Most players will only play DVD+R. It's the most popular and widely used format. Also some players will not play DVDR's burned above 4x but that's just some.
