Jump to content
long subwoofer cables
7 replies to this topic
#1 of 8 OFFLINE   John Menoni
John Menoni
  • 220 posts
Posted March 02 2005 - 05:02 AM
I need my subwoofer cables to be about 45 feet in length. I see that it is very hard to find a quality cable that is that long and is a good quality. Am I better off using two 25 footers and combining them with an adapter? Thanks John Menoni
#2 of 8 OFFLINE   John Menoni
John Menoni
  • 220 posts
Posted March 02 2005 - 05:07 AM
I also want to eventually add a second subwoofer to my outlaw audio 950 pre-amp. Should I look for a really long y-cable? Thanks, John Menoni
#3 of 8 OFFLINE   Gerry S
Gerry S
  • 122 posts
Posted March 02 2005 - 05:09 AM
Sounds like you need a custom job. There are custom cable makers around that will build a cable to your specs. I have this one bookmarked:
http://www.heartlandcables.com/
I've never purchased from them, but probably will in the future.
#4 of 8 OFFLINE   ChrisWiggles
ChrisWiggles
    Producer
  • 4,791 posts
Posted March 02 2005 - 06:21 AM
You can just get long coax cables and terminate them yourself, really cheap, the other common advice is to get long, really cheap coax that comes terminated with F-type connectors, then get little F->RCA adapter plugs and you're good to go. You shouldn't need to get one giant long Y cable, just get one of those short adapters for at the receiver, and run two long cables off of that. Subwoofer signals are very easy to transmit, so the cable quality and connection quality is not that big an issue as it would be if this were, say, video. Any cheapie coax, even run a long way, will be more than adequate for a sub connection.
#5 of 8 OFFLINE   Neil Joseph
Neil Joseph
    Lead Actor
  • 8,341 posts
  • Real Name:Neil Joseph
Posted March 02 2005 - 07:11 AM
I used the above approach / for 40+ ft runs with good results.
Click and enter " T H E . H O L O D E C K "
My Home Theatre "The Holodeck"
#6 of 8 OFFLINE   John Menoni
John Menoni
  • 220 posts
Posted March 02 2005 - 08:22 AM
Thanks for the info fellas!Posted Image I found a 2 in 1 cable from cinemacables.com for a good price. I am just going to go ahead and use that.
#7 of 8 OFFLINE   John Menoni
John Menoni
  • 220 posts
Posted March 02 2005 - 08:34 AM
I was all set to pay 112+ bucks on the cable from cinema cables and then I started looking around. I found the same set up that Chris and Neil used for $67.00. I decided to go with that plan. The M&K people told me that exotic subwoofer cable isn't worth it. Basically anything is good. Thanks for saving me a few bucks fellas. Posted Image
#8 of 8 OFFLINE   WayneLVS
WayneLVS
    Extra
  • 15 posts
Posted March 04 2005 - 02:20 AM
I can build custom cables in any length you need with rca ends crimped on........no adaptors See my thread "monster component video cables - custom lenghts" for info on the cable and connectors i use
