Head Unit/CD Changer problems (1 Viewer)
Marcus D
I had my factory head unit and speakers replaced with an Alpine Head Unit to go along with my Alpine 6 disc changer. I had an FM modulator that played/controlled the CD's in the CD changer. I had this removed so I could control the CD changer through the Alpine head unit. I already have a sub and amp connected as well. The problem I am having is when I turn the head unit on FM/AM I get bass from the sub and amp as normal. When I push Source Direct on the Alpine head unit to play my CD's from the CD changer or put in a CD in the head unit I get no bass from my amp or sub. I noticed that when I push Source Direct to play CD's, when I play the radio it obviously goes up. Do I need to add another connection or is something not connected. Please help
Scott L
That's a weird problem. Have you tried your question at caraudio.com or caraudioforum.com ? They may be able to help you.
acinstallation240
