Jump to content
General Instruments cable box and Tivo question
  • Please log in to reply
1 reply to this topic
#1 of 2 OFFLINE   Chris Wittry
Chris Wittry
  • 131 posts
Posted October 02 2001 - 07:20 PM
I was looking at buying a Tivo, but I have a question first. How does a Tivo work with a GI cable box? Do you use the Tivo guide or the cable guide to change channels? Does the Tivo control the cable box or vice versa? Just looking for how this works in general. Thanks! Posted Image
#2 of 2 OFFLINE   Mike Lang
Mike Lang
  • 51 posts
Posted October 03 2001 - 08:35 AM
You'll use the TiVo guide (but you can look at both) since you'll do all your scheduling with it. TiVo's control cable boxes with an IR blaster which is included.
