Jump to content
Speaker Cable for Bryston 9b st and Nautilus 805
  • Please log in to reply
4 replies to this topic
#1 of 5 OFFLINE   john.michael
john.michael
  • 28 posts
Posted February 24 2005 - 04:44 AM
Does anyone has a recommendation for a speaker cable to be used between my Nautilus 805s and a Bryston 9B ST? I will have to make a very long run (front to back about 30ft). I am currently thinking about the QED Silver aniversary or the Kimber 8TC. That should give you an idea of budget. many thanks
Do not go gentle into that good night
#2 of 5 OFFLINE   Greg_Hammond
Greg_Hammond
  • 38 posts
Posted February 24 2005 - 12:33 PM
The difference between one brand of 99.999% oxygen free copper speaker cable and another is usually the quality of the connectors, if any, and the appearance of the jacket. I use the semi-cheap Monster XP cable by the 100-foot roll because I like the flexibility of the jacket. If you want something that looks prettier, then by all means get what you like. It's more a matter of preference than performance. Now, when you start talking about RCA audio and coax digital cables, there is a little more proof in the pudding. The connectors, shilding, and dielectric can vary wildly from one quality cable to another. Greg
#3 of 5 OFFLINE   Robert Cowan
Robert Cowan
  • 504 posts
Posted February 24 2005 - 02:22 PM
haha, i love these threads! go to a high end store, goto a lower end store. buy one of each. spend an afternoon on your weekend, try each (but make sure you get a little used to them, dont just listen for 5 minutes and switch). put them on a credit card for an easy return and let us know which you like!
#4 of 5 OFFLINE   john.michael
john.michael
  • 28 posts
Posted February 24 2005 - 04:33 PM
Robert, Unfortunatly it is not that easy as I live in Brazil ans there are not so many dealers arround with those cables.
#5 of 5 OFFLINE   Scott Oliver
Scott Oliver
  • 1,159 posts
Posted February 25 2005 - 02:42 AM
Well since you live in Rio, sell both the speakers and the amps, and whatever preamp you have and go over to Eduardo de Lima of Audiopax and purchase a full Audiopax system.Posted Image
Posted Image
As for the other suggestion, I would look to something like entry level Tara Labs or Transparent. MY experience with Bryston amps, was that I wanted something a bit closed in on the highs. With more revealing cables things got too shrill for me quickly. I know there is a dealer in Sao Paulo who sells B&W, probably one in Rio for that matter as well, but have you called them and asked for an entry level suggestion that they would mate with B&W's?
