Jump to content
Looking for a flat panel TV under $2000, need advice
  • Please log in to reply
11 replies to this topic
#1 of 12 OFFLINE   Jim_Smith_
Jim_Smith_
  • 3 posts
Posted January 21 2005 - 03:09 AM
I am shopping for flat panel TV's. Both plasma and LCD are options. I will be using the monitor for both television and computer. For television, I will be watching mainly DVD's and DirecTV. HDTV is something I may get later. I am looking for a 42 inch, but will consider something smaller. I know I will be buying a low end unit, but picture quality is probably what I am looking for most. I will be sitting as close as 2 feet from it at times so picture quality is a must. My budget for a TV is $2000. I am currently considering this unit:
I have also looked at models from Akai and Panasonic. Any advice would be appreciated. Thanks, Jim
#2 of 12 OFFLINE   Michael TLV
Michael TLV
    THX Video Instructor/Calibrator
  • 2,909 posts
  • Real Name:Michael Chen
  • LocationCalgary, Alberta
Posted January 21 2005 - 03:15 AM
Greetings On the low end, Panasonic still does blacks better than the other two. Regards
Michael @ The Laser Video Experience
THX Video Systems Instructor/ISF Instructor
Lion A/V Consultants Network - TLVEXP.com
#3 of 12 OFFLINE   John S
John S
    Producer
  • 5,460 posts
Posted January 21 2005 - 03:19 AM
Yep, panasonic tends to be markedly better in the Extended Def Plasmas. I don't think there are any 42" LCD or larger in that price range is there?
#4 of 12 OFFLINE   Jim_Smith_
Jim_Smith_
  • 3 posts
Posted January 21 2005 - 03:49 AM
There are no 42 inch LCD's in that price range, but I am willing to go smaller if it means a much better picture. I was looking at a JVC 26 inch LCD for around $1500 I think.
#5 of 12 OFFLINE   John S
John S
    Producer
  • 5,460 posts
Posted January 21 2005 - 03:59 AM
The problem with smaller, is it can seem better just because of that.. It's smaller. I'd go with the plasma and size myself. I would choose an ED Panasonic Plasma over any of the more bargain HD Plasmas I have personally seen. There is so much more to a display than the raw resolution it can produce.
#6 of 12 OFFLINE   Mort Corey
Mort Corey
  • 981 posts
Posted January 21 2005 - 09:50 AM
I would think a 42" ED plasma viewed at two feet would be pretty ?????grainey???? Not something I think I'd choose for close up computer work anyway. Mort
#7 of 12 OFFLINE   Jim_Smith_
Jim_Smith_
  • 3 posts
Posted January 21 2005 - 10:01 AM
I have yet to see a plasma hooked up to a PC, so I have no clue what it will look like. I have duel monitor support and plan to have a 2nd 17 inch LCD for when I want to watch TV on the plasma and still work on the PC. I went to Best Buy and Circuit City tonight and looked at some displays. The Panasonic ED's did seem to have a slight better picture. All the lower end plasma's I looked at did have slight artifacting, but all looked good to me, even up close. I am still deciding.
#8 of 12 OFFLINE   Michael TLV
Michael TLV
  • 2,909 posts
Posted January 21 2005 - 10:33 AM
Greetings
Remember ... one does not buy a NEON and then complain that it performs like a NEON. Posted Image
Regards
#9 of 12 OFFLINE   SimiA
SimiA
  • 297 posts
Posted January 21 2005 - 05:40 PM
"I will be sitting as close as 2 feet from it at times so picture quality is a must." At 2 feet, a 42" plasma is out of the question. The sreen door affect alone would be annoying, not to mention the resolution of the set when used as a computer monitor just wouldn't cut it. You'd be able to see all the defects of the image being displayed. You might want to consider the HP L2335 23" LCD. A true 1920x1200 HD monitor. Just a thought. Vb
37 & 42" PWD6UY's
Mits HC 3000 FP
30" Apple Cinema LCD
#10 of 12 OFFLINE   Sceptre
Sceptre
  • 4 posts
Posted February 17 2010 - 04:14 AM
Have you looked in Sceptre LCD's?..42" LCD's are starting at $1,200. This is a really good price.
http://www.sceptre.com/Products/LCD/Specifications/spec_x420bv-F120.htm
This is how it looks if you want to see it...Hope this helps
#11 of 12 OFFLINE   SoundDoc
SoundDoc
    Extra
  • 18 posts
Posted November 14 2010 - 08:44 AM
Jim, You are confusing a computer monitor with a video display, which is quiet easy to do.  If you want a 42-inch display for TV and you aren't ready to show HDTV on it now - including BD movies - then WAIT and just purchase the size computer monitor you need, and it probably won't be 42-inches.  I have found that once the computer display gets above 23 or so inches that eye movement and placement of work objects gets to be a problem. So, while you think you may want a larger work surface, unless you  have entire areas of your surface where absolutely nothing is gong on and that doesn't bother you, go larger.  I also like being able  to pivot the display; something I can do at 23 inches, but not at 42 inches. All that said, the native display of a 23-inch monitor these days should be 1920 x 1080.  It can be higher, but no lower at that size. Then, if you want to watch HDTV on your monitor, you can. I have a 37-inch 1080 p monitor that I thought would make a great display, but it hasn't worked out that way because it simply has too much space. It's used for TV now.  I need to us my eyes microversions as I move across the screen, not macroversions that will lead to eye fatigue. Good lkuck
#12 of 12 OFFLINE   BenS
BenS
  • 210 posts
Posted November 19 2010 - 03:57 AM
I think he found the tv by now. lol This thread was from 2005.
Ben
