Jump to content
Sound Dynamics Thunder Series THS-3000 Subwoofer
  • Please log in to reply
9 replies to this topic
#1 of 10 OFFLINE   Val_r
Val_r
  • 3 posts
Posted January 10 2005 - 11:14 AM
Hey guys. I have the Sound Dynamics Thunder Series THS-3000 subwoofer above that I bought a couple years back from a friend, however the thing keeps blowing fuses. I am thinking that it's the power supply to the sub and am trying to replace it, however the company is not around anymore and nobody has ANY information about the sub. If anyone has any idea what type of power supply I need, knows whether it's the power supply at all, or has any information about the sub at all, it would be greatly appreciated. Thanks
#2 of 10 OFFLINE   Tom Vodhanel
Tom Vodhanel
  • 2,215 posts
Posted January 11 2005 - 04:21 AM
Hi Val, Does it blow fuses immediately each time you turn it *on*...or do the fuses blow only when the subwoofer is trying to reproduce loud bass? Tom V. SVS
#3 of 10 OFFLINE   Val_r
Val_r
  • 3 posts
Posted January 11 2005 - 08:59 AM
hey tom, thanks for the reply what happens is, i will replace the fuse and the sub will work great for a time period between 5 minutes and an hour or so. then it just randomly blows. it's not anything like a specific loud bass kick or peak, just completely random
#4 of 10 OFFLINE   stephanX
stephanX
  • 116 posts
Posted January 11 2005 - 09:21 AM
Well if the company no longer exists, and you dont know what the problem is. Why not just buy a new amp? Im sure partsexpress has one to suit your needs.
Can your 450$(cad) sub hit 120db at 40hz?
#5 of 10 OFFLINE   Val_r
Val_r
  • 3 posts
Posted January 11 2005 - 10:30 AM
tha amp and PS are all onboard the sub. please bear with me as i am fairly new to the home theater field. my thing is guitars. looking at the amp it says it's a 150 watt mosfet amplifier, and has a lp filter, phase, and some sort of an eq built into it however before buying a new amp i would like to confirm that it's not the power supply. thanks
#6 of 10 OFFLINE   Benihana
Benihana
  • 190 posts
Posted January 11 2005 - 11:44 AM
sound dynamics is made by API. if you cant find any info on sound dynamics(which is now Athena), you can find info on them from www.miragespeakers.com, they are from the same parent company API.
#7 of 10 OFFLINE   Chris Sherman
Chris Sherman
  • 378 posts
Posted January 11 2005 - 05:36 PM
Benihana is correct, Sound Dynamics was phased out and replaced by the Athena line. The chief designer is Gordo Van Kessel, owned by Audio Products International, they also make Energy as well as Mirage. You can contact them at 716-896-9801 , API National Service 203 Eggert Rd. Buffalo, NY 14215. They still stock parts for the Sound Dynamics line . I ordered a replacement grill from them and currently have a speaker being repaired, under warranty, by them.
#8 of 10 OFFLINE   Tom Vodhanel
Tom Vodhanel
  • 2,215 posts
Posted January 12 2005 - 09:30 AM
Wow, sounds like you may be in luck after all Val..Posted Image
If it turns out that they cannot help, please email me at SVS techsupport. We might be able to troubleshoot that problem a little further for you.
Tom V.
SVS
#9 of 10 OFFLINE   Chris Sherman
Chris Sherman
  • 378 posts
Posted January 12 2005 - 03:50 PM
I received my speaker back today . They replaced the woofer at no charge. The speakers had a 5 year warranty and I had my original sales receipt.I paid $8 to ship it to them and they paid return shipping. This is the only warranty issue, in over ten years of owning various API speakers, I am very satisfied in their handling of the repair. Turnaround was just under two weeks.
#10 of 10 OFFLINE   Benihana
Benihana
  • 190 posts
Posted January 12 2005 - 08:22 PM
Yes, all of API's speaker companyies are very helpful. Out of both the pairs of Mirage speakers that I bought, Mirage sent me spikes and panel dongs for free. Great service, I'm sure you will have no problem with sound dynamics.
