Budget surround sound system Is there one? (1 Viewer)
jimTesla
Well xmas maxed me out.....
I have a new toshiba 34 widescreen hdtv coming in with a stand....and adelphia cable coversion hdtv box coming....
I want to install a surround sound system for a small room
its 12 by 14 with the tv in the corner....
I want 5.1 at least....what are my options...
Educate me like you did with the TV...........
Jim
JohnCZ
Are you looking for everything??
Speakers, receiver, DVD player...
What is your realistic budget?
EricRWem
Adrik
I second the vote for that line of Onkyo HTIB's. 770, 870 if you want to go for a big kill. 770 is probably the best value for your dollar right now, imho. :emoji_thumbsup: :emoji_thumbsup:
JohnCZ
Good recommendations.
I would also add the Yamaha YHT-450 (w/o DVD) & the YHT-750 (with DVD).
Stephen Orr
Best Buy carries a Sony 5.1 Surround system that I bought for my son that does a decent job for $199.99.
DaveGTP
The Onkyo HTIBs are supposed to be very good for a HTIB. There's been deals on it ranging to about $400 for the 6.1 setup, and less for the 5.1 set.
Steve Adams
I would shop around for a decent receiver, sherwood, pioneer, panasonic, yamaha. you could probably pick one up pretty cheap now. and get the fluance speaker system. then get a now discontinued sony sa-wm40 subwoofer and you have the makings of a great sounding budget system.
Philip Hamm
If you're looking for something that looks slick and takes almost zero space, check out the Sony Dream Systems. My brother has one and it's outstanding!
H-508
