Jump to content
Paradigm Center Speaker cc370 problem
  • Please log in to reply
16 replies to this topic
#1 of 17 OFFLINE   Kathy C.
Kathy C.
  • 49 posts
Posted December 18 2004 - 05:03 AM
My Paradigm cc370 center doesn't sound clear. My system is: Sony KPHW 40 50" P. Mini's --fron P. Titan's-back Denon 2802 receiver 12 gauge wire PDR 10 sub We've had this system up for about 2+ years, and I bought most new from retailers, but some over ebay. This speaker came from ebay, boxed as new, still in plastic, foam, etc. It has always had a little bit of an unclear sound, fuzzy timbre and not as clear as the other speakers. I always feel I have to turn up the volume to understand the words. We figured the problem involved the settings. Now, by college-son wants it fixed, NOW. Any suggestions about making sure the settings are correct. I knew all about this when I set it up and researched everything to death, but now, I'm a little fuzzy myself on everything. I was going to call a retailer in Dallas, but I figured they'd not be happy with my ebay purchase. Thanks, Kathy
#2 of 17 OFFLINE   Aaron Waters
Aaron Waters
    Extra
  • 21 posts
Posted December 18 2004 - 05:49 AM
so many options. i had a cc370 a few years ago and the tweeter went bad. it became worse over time, but very fast nonetheless. although, it was muffled, and not fuzzy. 1 set your denon receiver settings to defaults. speakers to small, sub to yes, and all channel levels to zero. (no + or -) still a problem? 2 put one of your mini monitors in the center channel position and see if you notice the same sonic characteristics? still a problem? 3 can you take the cc370 to the dealer and have them try it out? it's much easier to diagnose that way. 4 e-mail paradigm's tech support. you can get the info from paradigm's website. paradigm's tech support will assist in providing a new tweeter, etc. i also had a bad solder joint on BOTH of my mini monitors. i would not be surprised if something is wrong with the speaker (maybe obvious already to you).
#3 of 17 OFFLINE   Kathy C.
Kathy C.
  • 49 posts
Posted December 18 2004 - 09:28 AM
thanks for the input--we tried the mini and it sounds GREAT!! what a difference. We took the speaker in and it was a bad tweeter. since I'm out of warranty, is this something I can replace myself? How much does a tweeter run from paradigm? Kathy
#4 of 17 OFFLINE   Jeff-0
Jeff-0
  • 60 posts
Posted December 18 2004 - 10:42 AM
warranty is out because of purchasing from ebay?? i ask because the 370 has like a 5 year warranty or something like that. i purchased mine from a authorized dealer and i swear he said i have 5 year warranty on it. im sure you can purchase the tweeter directly from paradigm.......
#5 of 17 OFFLINE   Aaron Waters
Aaron Waters
    Extra
  • 21 posts
Posted December 18 2004 - 10:50 AM
i do not have permission to post links because of my low post count.
go to paradigm's website.
paradigm
dot
com
click on Paradigm Site, click on Tech Support and you'll see an e-mail address towards the top left.
e-mail them and tell them your situation. i believe (gary?) will help you purchase a new tweeter through their supplier. you can Private Message me if you want an idea of price. i think i remember how much it cost me, but i won't post $ on the site.
just wanted to add the following as it seemed you had reservations about contacting a dealer...
you were unsure about dealing with the folks in dallas. don't be afraid to e-mail paradigm. they won't close the door on you.
yes, it's very simple to replace. just unscrew the tweeter enclosure. you'll see two wires going into the sides of it. you'll pop the new one in there and hook up it all the same. no more fuzzies. Posted Image
#6 of 17 OFFLINE   Kevin. W
Kevin. W
  • 1,546 posts
Posted December 18 2004 - 11:27 AM
Email Tech Support at Paradigm and explain your situation. You say you've had the speaker for 2yrs so Paradigm may still honor your claim, otherwise they should be able set you up with a new one. Kevin
#7 of 17 OFFLINE   Kathy C.
Kathy C.
  • 49 posts
Posted December 18 2004 - 02:26 PM
this is very encouraging.....but I don't think I bought the speaker from an authorized dealer..just an individual. I'll check with paradigm about the possibility of any warranty help. the replacement of the tweeter has got to be less than replacing the whole speaker!! I"ll let you know the outcome. K.
#8 of 17 OFFLINE   GrahamT
GrahamT
  • 556 posts
Posted December 19 2004 - 12:14 AM
The tweeter is $70 CDN and probably about the same in US dollars.
#9 of 17 OFFLINE   Kathy C.
Kathy C.
  • 49 posts
Posted December 20 2004 - 03:12 PM
I emailed paradigm--"gary" replied that I did not have a warranty and to purchase a tweeter through an authorized dealer. So....guess I'll have to pay a little more and go that route. Thanks for your input. Kathy
#10 of 17 OFFLINE   Owen Bartley
Owen Bartley
  • 486 posts
Posted December 21 2004 - 02:54 AM
Kathy, I have a similar tweeter problem, and will be emailing Paradigm today. I'll let you know how it goes. My tweeter has distinct buzz, especially on male voices, at moderate (well below reference) levels and I'm thinking it needs replacing.
#11 of 17 OFFLINE   GrahamT
GrahamT
  • 556 posts
Posted December 21 2004 - 04:16 AM
Just an FYI, the buzzing on the V3 monitors is caused by the diaphragm plate vibrating against the faceplate. I have taken 2 V3 speakers in to get replaced and the noise eventually came back. I have had it happen to 2 cc370s and a mini. I took them apart carefully and put lube between all the parts and reassembled and the noise never came back.
#12 of 17 OFFLINE   Kathy C.
Kathy C.
  • 49 posts
Posted December 21 2004 - 05:42 AM
my problem is not buzzing, but a muffled sound. It checked out as the tweeter. I'll remember your fix for the buzzing ....just in case
#13 of 17 OFFLINE   Rick Lyon
Rick Lyon
  • 88 posts
Posted March 19 2005 - 02:50 AM
I have a similar question about my 370, but it's more like clipping or a resonating type of vibration. On deep voices that scream, there's vibration (or slight distortion) at the peak of the tone. Is there a test that can be done to determine if it's the tweeter? Like playing a sweep or something? My dealer would need the speaker dropped off for a day or two to check it, I'd rather verify a problem or not myself.
Couldn't come up with anything clever
or exciting other then to explain the
fact that I was lazy.
#14 of 17 OFFLINE   Jeff-0
Jeff-0
  • 60 posts
Posted March 19 2005 - 04:53 AM
I used the cc-370 with great success, it handled everything i could throw at it. Voices were always spot on and clear.
#15 of 17 OFFLINE   Weilin_S
Weilin_S
    Extra
  • 23 posts
Posted March 19 2005 - 07:43 AM
If you are near me, zip 47906. I can help you to get a tweeter from my loacl dealer. I have a receipt for CC370. However, my dealer wants to check the speaker before they order a tweeter for me.
#16 of 17 OFFLINE   Rick Lyon
Rick Lyon
  • 88 posts
Posted March 20 2005 - 06:07 AM
GrahamT - I read your post, sounds interesting and my be my problem as well. Can you elaborate on the 'lube' you used? And did you put it between the tweeter and the star shaped faceplate?
#17 of 17 OFFLINE   Ralph B
Ralph B
  • 583 posts
Posted March 20 2005 - 09:14 AM
yes would like to hear what lube you used too incase I ever had a problem. I am glad I have never had problems with any of my version 3 Paradigms.
