Jump to content
65" Rear Projection HDTV too big for 12-13' viewing distance?
  • Please log in to reply
22 replies to this topic
#1 of 23 OFFLINE   Dave H
Dave H
    Producer
  • 5,308 posts
Posted December 16 2004 - 11:18 AM
The subject says it all. I tried the calculator that's going around, but it doesn't give minimum distance. What are your experiences? Not sure if I should go 55 or 65.
#2 of 23 OFFLINE   Shane Martin
Shane Martin
    Producer
  • 6,017 posts
Posted December 16 2004 - 11:38 AM
I've heard that if you want alot of HDTV that closer is fine. I sit back around 10 feet from my 55 and that is just right. I don't have my HD online yet though. I would think it is too big but others should chime in.
#3 of 23 OFFLINE   Gregg Loewen
Gregg Loewen
    Video Standards Instructor, THX Ltd.
  • 6,362 posts
  • Real Name:Gregg Loewen
  • LocationNew England
Posted December 16 2004 - 03:04 PM
I just did a touch up job on a 65 " Tosh. The viewing distance was 11 feet ish. DVDs looked fine...analog cable looked pretty bad. YMMV, Gregg
The Sonodome - circa 2001
The Newest Sonotube - circa 2001
Gregg's DVDs updated...sometimes
Lion Audio Video Consultants usually current
#4 of 23 OFFLINE   Dave H
Dave H
    Producer
  • 5,308 posts
Posted December 16 2004 - 03:51 PM
On a side note....is red push an issue still with Mits?
#5 of 23 OFFLINE   Shane Martin
Shane Martin
    Producer
  • 6,017 posts
Posted December 16 2004 - 11:57 PM
I responded to your email Dave. I don't see it as an issue especially now that I can tweak that out of the perfectcolor menu.
#6 of 23 OFFLINE   Nathan Stohler
Nathan Stohler
  • 329 posts
Posted December 17 2004 - 03:27 AM
As Shane said, if you're going to be doing a lot of HD viewing, closer is fine, since your eyes have a harder time resolving the pixelation.
I have a 52" GE Best Buy special ($888) and analog TV looks pretty poor compared to DVDs, which look pretty sharp (I'm sitting about 10' away). I haven't yet pulled the trigger on a DirecTV HD unit, but I probably will once there is more HD programming available.
Also, keep in mind that once you get used to your new TV, it won't seem as big as the day you got it, so I'd say go for the 65-inch. Posted Image
#7 of 23 OFFLINE   Dave H
Dave H
    Producer
  • 5,308 posts
Posted December 17 2004 - 04:59 AM
I am going to be watching analog material -- even thought I am getting HD cable. The stations I watch the most won't be HD televised. How, DVDs are going to be my #1 viewing. I want my TV and screen size/distance, etc. optimized for them.
#8 of 23 OFFLINE   Jerome Grate
Jerome Grate
  • 2,937 posts
Posted December 17 2004 - 06:52 AM
If you are hung up on Digital cable, then the responses are what to expect. I use DirecTV and the SD (Standard Definition) is pretty good through my 51 inch Sony via S-Video. My scheme is to pick up an OTA HD box and antennae and view the free HD channels and then watch regular t.v. via satellite and of course DVD via upscaled through component.
Listen Up People.., Rack Em and Pack Em.., We're Phantoms in 15.
#9 of 23 OFFLINE   Dave H
Dave H
    Producer
  • 5,308 posts
Posted December 17 2004 - 07:20 AM
What kind of upscaled dvd player do you have? Does it make a difference than a regular progressive scan?
#10 of 23 OFFLINE   Jerome Grate
Jerome Grate
  • 2,937 posts
Posted December 17 2004 - 07:53 AM
I have the Zenith DVB-318, set to 1080i via component. Now the Sony t.v. (KPS51WS520) upscales everything to 480p and it does a pretty good job, but when DVD movies are set for 1080i on this player, it by far passes 480p. I did a comparison with Fifth Element and the scene I used was on the Cruise Ship with Bruce Willis and Chris Tucker as Chris Tucker is still on the radio broadcast. The sweat on Chris Tucker is so clear it the closest thing to HD you going to get. In 480p, don't get me wrong the picture is good, but it lacked the detail 1080i was giving.
#11 of 23 OFFLINE   Dave H
Dave H
    Producer
  • 5,308 posts
Posted December 17 2004 - 09:11 AM
Shane or anyone else, What does the Mits 313 or 315 upscale to? Is this of anything benefit to me? Thanks.
#12 of 23 OFFLINE   Arthur S
Arthur S
  • 2,572 posts
Posted December 17 2004 - 09:14 AM
I'm watchin a Toshiba 65 H 84 from about 11 feet. I use Comcast cable with HD. HD via Comcast is everything I had hoped for. Some of the standard definition channels are only fair, some are pretty good. I would not want a smaller set. DVD with my Proscan DVD player is almost as good as HD. I also picked up a second DVD player that delivers outstanding picture quality. Toshiba SD 3960. This little thing only costs $70 and is not one of those that delivers 1080I. You have to be careful about numbers games. For example, the Sony KE-42M1 Plasma is only an ED-TV. It can't display 1080I. However, picture quality equalled that of the top rated Panasonic HD Plasma costing $2,000 more. So far there is only ancedotal information that the 1080I DVD players can actually deliver a better picture than other DVD players. Also, the latest players have to be hacked to output 1080I from the component outputs. People are driving themselves crazy over build dates, hacks, etc. for something that (IMHO) is largely a cult phenomenon, like putting green magic marker around the outside of a CD. Artie
#13 of 23 OFFLINE   Dave H
Dave H
    Producer
  • 5,308 posts
Posted December 17 2004 - 09:15 AM
Gregg, I have a few questions for you based on your experience: 1. I am really thinking about the Mitsubishi (WS-65315) How does this set compare with Toshiba, Sony, Hitachi in the same class/price models? 2. While I mean leaning 65", it seems the 55" gives a tighter picture because of it be smaller. Is this true? Smaller screen size = more crisp image? 3. How are the Mits out of the box? I am going to get it ISF'd anyway, but was just curious. 4. Also, how is the overscan on them? I could have my ISF guy fix this, but if I can avoid it, the better. Anyone else feel free to jump in. Thanks.
#14 of 23 OFFLINE   Arthur S
Arthur S
  • 2,572 posts
Posted December 17 2004 - 09:20 AM
Dave I would check with ONECALL they have had the Toshiba 65H84 for $1799 delivered using their own price match. They are down in stock right now and I don't know if or when they will have it back at $1799, but that seems to be an amazing delivered price for a very good set. I would give them a call and see if they expect to get any more at that price. As far as how it compares to Mits, Sony etc, it holds its own very well. Artie
#15 of 23 OFFLINE   Brian Gi
Brian Gi
  • 122 posts
Posted December 17 2004 - 12:50 PM
Our front row is 13 feet from a 104" diag widescreen 720P projector screen. You'll be fine with a small 65" TVPosted Image
#16 of 23 OFFLINE   Dave H
Dave H
    Producer
  • 5,308 posts
Posted December 17 2004 - 04:19 PM
Do you guys suggest I go with a DVI connection if I just get the Panasonic XP30 Progressive player? Is DVI better than component?
#17 of 23 OFFLINE   Lewis Besze
Lewis Besze
    Producer
  • 3,134 posts
Posted December 18 2004 - 12:35 PM
Yes in theory. DVI carries the digital signal and component is analog.Also as some pointed it out most "upscaling" players can't send that info via component outs[unless it's "hacked"],only either DVI or HDMI.
#18 of 23 OFFLINE   Chris_Matthews
Chris_Matthews
  • 12 posts
Posted December 18 2004 - 12:45 PM
A little over 10' from my 92" screen and everything looks fine.
#19 of 23 OFFLINE   Sami Kallio
Sami Kallio
  • 1,035 posts
Posted December 18 2004 - 03:53 PM
12 feet, 100+ inches and 480i. Looks great. Whether 65" is too big really depends on you and what you want.
#20 of 23 OFFLINE   Gregg Loewen
Gregg Loewen
  • 6,362 posts
Posted December 19 2004 - 03:01 AM
you cant directly compare the viewing distances with different technologies. Personally, Id recommend the Mits over the Tosh. Id dont think you would visually notice a difference between 55-65" on a RPTV....if this is a big hurtle for you to get over, consider one of the Mits with 9" crts. all of the sets are "okay" out of the box. If you are going to have your ISF tech calibrate it, why not ask him for buying assistance. I know I always offer free advice to established clients. regards Gregg
