Jump to content
Outside coating for non shielded (and shielded) speakers.
  • Please log in to reply
4 replies to this topic
#1 of 5 OFFLINE   Gabriela Mendez
Gabriela Mendez
  • 111 posts
Posted December 03 2004 - 06:07 AM
Anyone know of some material to protect a CRT TV from Speaker magnets? Even though my floor speakers are shielded, they still tamper with my tv screen. Any way of covering the speakers from the outside or a simple solution other than replacing/removing/moving the speakers?
#2 of 5 OFFLINE   John Garcia
John Garcia
    Executive Producer
  • 11,566 posts
  • Real Name:John
  • LocationNorCal
Posted December 03 2004 - 07:13 AM
Moving them further away is your simplest answer (assuming you have room). There is a material called "Mu-metal" that can be used to cut down EMF, or a thin sheet of stainless steel.
HT: Emotiva UMC-200, Emotiva XPA-3, Carnegie Acoustics CSB-1s + CSC-1, GR Research A/V-1s, Epik Empire, Oppo BDP-105, PS4, PS3,URC R-50, APC-H10, Panamax 5100 Bluejeans Cable
System Two: Marantz PM7200, Pioneer FS52s, Panasonic BD79
(stolen) : Marantz SR-8300, GR Research A/V-2s, Sony SCD-222ES SACD, Panasonic BD-65, PS3 60G (250G)
Everybody is a genius, but if you judge a fish by its ability to climb a tree, it’ll spend its whole life believing that it is stupid.” – Albert Einstein
#3 of 5 OFFLINE   JamesCB
  • 440 posts
Posted December 03 2004 - 12:28 PM
I would consider contacting your dealer or having them serviced if they are under warranty. Any speaker that claims to be sheilded should not interfere with the monitor. If you are having this problem, I would suspect the bucking magnets may be faulty or may not be installed properly. How close are the speakers to the monitor? Even unsheilded speakers usually do not interfere with the monitor, even if they are as close as 12", of course depending on the strength of the magnets. Moving them now is also very important as constant magnetic fields can permanently damage a monitor over time. What speakers are you using? James
#4 of 5 OFFLINE   Gabriela Mendez
Gabriela Mendez
  • 111 posts
Posted December 06 2004 - 02:43 AM
JBL SVA1800. I wonder if a electric socket could tamper the screen. This only happens on the right side of the monitor. By the way, when I upscale to 1080i (zenith dvb318 & xbox). I get lines on that same side of the TV. Something minor, but still a burden. I'll try moving the TV and see if this goes away.
#5 of 5 OFFLINE   Louisp
  • 168 posts
  • Real Name:Louis Patrick
  • LocationNorth Texas
Posted December 07 2004 - 03:03 AM
I see that your speakers are JBL from the HK folks. Now let me guess, your television is a Sony. Even if it's not here's some information for you.
This solution uses flat 16 gauge sheet steel which is commonly available from Lowes, Home Depot, ACE and like stores.
(hint 1 - use heavy duty mounting tape to adhere the sheet metal.)
(hint 2 - wax (do not wax tape areas) the metal sheeting to avoid rusting.
(hint 3 - when the sheeting is used on the exterior of the speaker it may be painted to match the speaker.)
Check this out.
To add additional shielding within the speaker case: Open the case, determine the most appropriate location and take measurements.
To add additional shielding outside of the case: Determine the appropriate location (if not the entire side) and take measurements.
Posted Image
Sony HDTV KDL-46HX750, Denon AVR 1912, DirecTV HD DVR HR44,
DirecTV AM21 OTA Receiver, Panasonic DMP-BD65 Blu-ray,
Toshiba HD DVD A20, Infinity Alpha Speakers 50's, 20's, 10's, 37c,
Valodyne Subwoofer, Panamax M4300-PM, Monoprice Cables
