Jump to content
"Hiss" Problem
16 replies to this topic
#1 of 17 OFFLINE   Jay Foster
Jay Foster
  • 160 posts
Posted November 29 2004 - 01:19 PM
I have what sounds to me like a "hiss" coming out of my speakers when I am playing a DVD. I can only hear it during the very quiet parts of a movie. Does anyone know what is causing the problem and how I can fix it. Thanks.
Jay Foster
#2 of 17 OFFLINE   Kevin C Brown
Kevin C Brown
    Producer
  • 5,713 posts
Posted November 29 2004 - 05:36 PM
What happens when you pause the DVD? Might just be background noise from the DVD soundtrack. Do you get the same amount of hiss from different movies? If you raise and lower the volume, does the volume of the hiss change?
If it's not worth waiting until the last minute to do, then it's not worth doing.
KevinVision 7.1 ...
#3 of 17 OFFLINE   Jay Foster
Jay Foster
  • 160 posts
Posted November 30 2004 - 11:16 AM
Kevin,
I'll check on this. I haven't noticed whether it is the same amount from different movies. I do know that if I raise and lower the volume, the volume of the hiss does change as you raise and lower it.
Jay Foster
#4 of 17 OFFLINE   John Garcia
John Garcia
    Executive Producer
  • 11,553 posts
  • Real Name:John
  • LocationNorCal
Posted November 30 2004 - 12:13 PM
Hiss can come from a number of places. If you give a list of your gear and how you have it connected, it will probably help in diagnosing.
HT: Emotiva UMC-200, Emotiva XPA-3, Carnegie Acoustics CSB-1s + CSC-1, GR Research A/V-1s, Epik Empire, Oppo BDP-105, PS4, PS3,URC R-50, APC-H10, Panamax 5100 Bluejeans Cable
System Two: Marantz PM7200, Pioneer FS52s, Panasonic BD79
(stolen) : Marantz SR-8300, GR Research A/V-2s, Sony SCD-222ES SACD, Panasonic BD-65, PS3 60G (250G)
Everybody is a genius, but if you judge a fish by its ability to climb a tree, it’ll spend its whole life believing that it is stupid.” – Albert Einstein
#5 of 17 OFFLINE   Kevin C Brown
Kevin C Brown
    Producer
  • 5,713 posts
Posted November 30 2004 - 12:20 PM
Let us know all that. If it's a hiss and not a hum, I have a suspicion, but I want to see what gear you have first. Posted Image
KevinVision 7.1 ...
#6 of 17 OFFLINE   Jay Foster
Jay Foster
  • 160 posts
Posted December 01 2004 - 03:38 PM
I can give a specific example now. In Spiderman 2, the very last scene where his girlfriend is in her wedding dress at his apartment. To me, it is definitely a hiss and not a hum. The hiss is prominent. I was playing the Spiderman movie loud.
My gear: I just bought Mirage speakers, Omni 250s, Omni CC, and Omni FX (although I noticed the hiss with my old speakers also). I have an older JVC receiver/amplifier powering them. Model Number RX-888V. I am using a Liteon DVD player.
My speakers are connected with 12 gauge copper wire and the amplifier and speakers have binding posts on them.
Jay Foster
#7 of 17 OFFLINE   Kevin C Brown
Kevin C Brown
    Producer
  • 5,713 posts
Posted December 01 2004 - 06:00 PM
Ok, nothing stands out there. Because they are so efficient, sometimes Klipsch speakers with some amplifiers can have hiss problems. Try to see how different soundtracks sound. I have Mirage speakers myself, some OM some Omni series, and I know they probably aren't the culprit. Could be the JVC but I just don't know. How far out from the speakers can you hear the hiss. From where you sit?
KevinVision 7.1 ...
#8 of 17 OFFLINE   John Garcia
John Garcia
    Executive Producer
  • 11,553 posts
  • Real Name:John
  • LocationNorCal
Posted December 02 2004 - 04:11 AM
There's a chance its in the recording, because if you don't notice all the time, it is just the amp amplifying background noise in the recording. Its just doing its job, and it amplifies the bad with the good.
If you have hiss when nothing is playing, that is a different story, and I'd suspect the JVC as well. The problem may be that the receiver is underpowered for the SPL that you are looking for. A more powerful amp will allow you to achieve the same SPL without turning the amp up to where you hear the hiss.
#9 of 17 OFFLINE   Jay Foster
Jay Foster
  • 160 posts
Posted December 03 2004 - 03:51 PM
Hi all,
I can hear the hiss from where I sit. I have not noticed if I can hear it when nothing is playing. I'll check that. When you play your dvds at high volume do you hear a hiss also?
Jay Foster
#10 of 17 OFFLINE   Kevin C Brown
Kevin C Brown
    Producer
  • 5,713 posts
Posted December 03 2004 - 07:46 PM
I'm not sure what you mean by high volume. I usually listen to movies at -15 dB to -10 dB (to reference). I don't hear any hiss except if I put my ear right up against the speaker.
Is the hiss different for different movies?
One thing you have to be careful of though, let's say you're watching a movie and you hear hiss. Then you pause the movie. Some receivers engage digital muting at that point, which might artificially get rid of the hiss.
KevinVision 7.1 ...
#11 of 17 OFFLINE   Jay Foster
Jay Foster
  • 160 posts
Posted December 06 2004 - 04:59 PM
The hiss is the same for all movies. It almost sounds like an lp being played. You know the sound in between the songs on an lp? It sort of sounds like that. A salesman where I bought my Mirages says it may be my amp.
Jay Foster
#12 of 17 OFFLINE   frank manrique
frank manrique
  • 798 posts
Posted December 07 2004 - 07:53 AM
The hiss problem arises somewhere from your electronics...
How is your DVD connected to the receiver/amp/preamp components? I would try an optical Toslink cable to output digital sound between the DVD player and whatever you're using as pre/pro and amp (or receiver) and see (hear) if the hiss disapears or lessens in magnitude (most audio system produce an small amount hiss, but usually not noticeable until one gets very close to the speakers high frequency drivers or tweeters).
Also, keep all electronics connected to the same AC power source as much as possible. This will eliminate ground loops (ground loops introduce audible hum into the system).
Good luck on your quest... Posted Image
-THTS
"...hi, my name is Frank...and am an SVS bassaholic..."
#13 of 17 OFFLINE   Kevin C Brown
Kevin C Brown
    Producer
  • 5,713 posts
Posted December 07 2004 - 12:33 PM
Is there an easy way for you to try another receiver?
KevinVision 7.1 ...
#14 of 17 OFFLINE   Kevin. W
Kevin. W
  • 1,546 posts
Posted December 08 2004 - 12:26 AM
I'd bet the problem is your receiver. Easy way to test it is to turn only the receiver on and see if the hiss occurs as you turn the volume up. Try different inputs on the receiver without a source turning the volume up and down for each input and see if you hear the hiss. Your speakers are very sensitive and will pickup any EMI/RFI the receiver is putting out. Just make sure you do not have the mute on and when you turn to the tuner input the volume is turned down.
Kevin
#15 of 17 OFFLINE   Rick_Brown
Rick_Brown
  • 449 posts
Posted December 08 2004 - 02:14 AM
Have you by chance turned up the treble contol too high?
#16 of 17 OFFLINE   Kevin C Brown
Kevin C Brown
    Producer
  • 5,713 posts
Posted December 08 2004 - 12:38 PM
Jay- Kevin W's test is a good one, just be sure that any digital muting is not engaged like I mentioned up in post 10. 'Course, depending on what the problem is, might not even matter.
KevinVision 7.1 ...
#17 of 17 OFFLINE   David S
David S
  • 166 posts
Posted December 09 2004 - 09:50 AM
Like what? My lp's are dead silent between songs, its those damn noisy cd'sPosted Image
