Jump to content
Problems with West Wing Season 3, Disc 1
  • Please log in to reply
11 replies to this topic
#1 of 12 OFFLINE   Greg O' Connel
Greg O' Connel
  • 191 posts
Posted November 03 2004 - 06:13 PM
On the episode Manchester Part II, there is heavy skipping and pixellization around the 18-22 minute mark, in a few places. I've played in in 3 DVD players, and the effects are all there, in varying degrees. I wonder if this is safe to return for a different disc, or if this is a widespread problem where they will have to reprint discs?
"I hate television. I hate it as much as peanuts. But I can't stop eating peanuts." - Orson Welles
#2 of 12 OFFLINE   James Lambert
James Lambert
  • 118 posts
Posted November 03 2004 - 11:12 PM
Got the set yesterday, and was watching it last night. I got to about half way through Manchester Part II, but not sure if I passed the 18-22 minute mark (I was tired). I noticed no problems whatsoever, so either it's not a widespread problem, or I turned it off just before I got to your problem. One thing I did forget was the lighting scheme to the show, which makes eveything look quite soft, but it's always been like that with the west wing.
Knowing my luck, if there is such a thing as re-incarnation, I'd come back as me!
#3 of 12 OFFLINE   Gary Nash
Gary Nash
  • 35 posts
Posted November 04 2004 - 07:26 AM
No problems with Disc 1, but I had major problems with Disc 2 side B. At ch3-4 transition (00:20:31), picture pixellates really badly, freezes, stutters etc. If you try skipping from ch3-4, it skips 4 and goes straight to 5. Using the play-all option shows the error at the same point (but different refs ch15-16 01:47:19. I'm asked my dealer if I can just replce the faulty disc as the others work fine and I don't want to exchange the whole set and find I get a dodgy Disc 1 !!
#4 of 12 OFFLINE   Greg O' Connel
Greg O' Connel
  • 191 posts
Posted November 04 2004 - 10:18 AM
After looking at the disc a little more closely, it seems to have the trademark signs of layer separation (at least I think that's what the technical term is), where there's odd bits of glue around the center of the disc beneath the outer plastic layer. I took it back and exchanged it, and the problem is solved.
#5 of 12 OFFLINE   James Lambert
James Lambert
  • 118 posts
Posted November 04 2004 - 11:37 PM
Excellent to hear Greg! I did log on to say that I watched all of Manchester Part II last night and had no problems whatsoever. However Gary Nash's post has disconcerted me a little. Suppose I won't know till I finish the season. Still gotta say I hate the DVD-18 format anyway, thank goodness I had no floaters when I received it. Anyone know when Season 4 is released, as the R2 discs seem inferior, certainly season 1 was.
#6 of 12 OFFLINE   JasonBrown
JasonBrown
  • 62 posts
Posted November 05 2004 - 02:40 AM
The blooper reel, mentioned on the packaging and the inside booklet, are nowhere to be found on these discs, right?
#7 of 12 OFFLINE   Rob T
Rob T
  • 1,991 posts
Posted November 05 2004 - 05:20 AM
I've watched most of disc 1 and I've had no problems so far. Posted Image
#8 of 12 OFFLINE   Yee-Ming
Yee-Ming
    Producer
  • 4,333 posts
  • Real Name:Yee Ming Lim
Posted November 07 2004 - 05:01 PM
FWIW, I've gone through the whole of Disc 1 so far, no problems.
#9 of 12 OFFLINE   Seth R
Seth R
  • 7 posts
Posted November 08 2004 - 05:15 AM
I too ran into the same problem with disc 2 (although side A). Right around the 22:00 mark it starts to stutter and then finally locks up. Tried it on a few different players, all of which lock at exactly the same place (although the behavior up to the lock differed some from player to player). My disc 1 was problem free and so far disc 3 seems fine.
#10 of 12 OFFLINE   James Lambert
James Lambert
  • 118 posts
Posted November 09 2004 - 12:41 AM
I'm halfway through Disc 2, and (touch wood) not had any problems whatsoever. It does sound though that this may be a problematic set. On a side note, I'm really enjoying this season. When watching it on TV I felt let down after the superb 2nd series, but it seems to be playing much better the second time around.
#11 of 12 OFFLINE   Yee-Ming
Yee-Ming
    Producer
  • 4,333 posts
Posted November 09 2004 - 03:19 PM
Update: on side B of disc 2, I had some pixellation (a small nasty green square showed up, a bit of freeze-framing on video though audio was fine), but it wasn't serious and I was still able to watch the episode all the way through (either ep 15 or 16) without missing anything substantively.
#12 of 12 OFFLINE   Gord Lacey
Gord Lacey
  • 2,447 posts
Posted November 09 2004 - 06:50 PM
I know there was a problem with one of the sets (season 1 I believe). Same thing people are describing here: pixelation and picture breakup, but it only occured on Sony players and Mac computers (both of which I have). When I got my Panasonic DVD-R the first thing I did was test the faulty disc and it played fine. Gord
Want to see your favorite show on DVD?
