Jump to content
Questions about DVD out coax vs. optical and component cables and switch
3 replies to this topic
#1 of 4 OFFLINE   Fred Meyer
Fred Meyer
  • 3 posts
Posted October 29 2004 - 08:14 AM
Hi. I have several questions. I would appreciate any and all info and/or links. Thanks in advance. Fred 1. I am currently using the A/V connection on my DVD player to connect audio. My DVD player and my receiver both have coaxial and optical digital jacks. Could you link to the basics of what these are all about and whether or not there will be significant improvement if I use them. 2. I need a few component video cables and a component video switch. I also need a couple s-video cables and a couple a/v cables. Which website(s) do you recommend to buy these items?
#2 of 4 OFFLINE   Fred Meyer
Fred Meyer
  • 3 posts
Posted October 29 2004 - 09:09 AM
I found the answer to question 1 on my own. I could use a recommendation or two on question 2 still. Thanks. Fred
#3 of 4 OFFLINE   ChrisWiggles
ChrisWiggles
    Producer
  • 4,791 posts
Posted October 29 2004 - 09:23 AM
question 2: revolves around how good cabling you want. For most regular type setups, stuff like AR or Radio shack cabling is fine, and not expensive. Monster is usually touted as being overpriced, but is also good cable, though I would go for the AR/radio shack cabling, it's about the same. For monster prices, you can get the best cabling by getting custom canare/belden type cabling, this is pro-grade cabling that is used in pretty much any studio on earth, and is pricier than run-of the mill quality cables, but if you have long runs, or very high end displays, etc, it's good. sources like bluejeanscable.com and other online vendors are good for the pro-grade stuff.
#4 of 4 OFFLINE   Byron_T
Byron_T
    Extra
  • 24 posts
Posted October 29 2004 - 09:26 AM
It would help if you would tell us what DVD player and Receiver you are using. As far as question 1. The only way you will be able to get 5.1 sound is through the coax or optical connection.
If the facts don't fit the theory, change the facts.
Albert Einstein
