Jump to content
Need solutions for flattening frequency response....
  • Please log in to reply
5 replies to this topic
#1 of 6 OFFLINE   Jeff_Wi
Jeff_Wi
  • 53 posts
Posted October 19 2004 - 04:26 PM
I recently ran some frequency sweeps using Spectrum Lab and a Radio Shack spl meter.
http://pg.photos.yah...lbum?.dir=/8848
Can someone recommend what is the best approach to reducing the nasty bump centered at 80Hz? I have read about the BFD being good for this, but what about broadband eq, such as a 31-band eq? I have tried multiple xover settings and phase settings. The problem is actually coming from my mains, in conjuction with the room properties
#2 of 6 OFFLINE   MingL
MingL
  • 214 posts
Posted October 19 2004 - 04:36 PM
The free way is to adjust the x-over on the sub to a lower value. At 80Hz, it may be the case that both the subs and mains are active at the same time and they are reinforcing each other (thats probably why 80hz is approx 6dB higher) Maybe try crossing over at 60hz or 70hz and things may just measure better.
#3 of 6 OFFLINE   Jeff_Wi
Jeff_Wi
  • 53 posts
Posted October 19 2004 - 05:57 PM
Well, actually the xover is set to the lowest of 40Hz. I measured the response of the sub only and the true slope is at about 70Hz -3db. By the way, can anyone see my graph? It was there at first, I think. Now it isn't.
#4 of 6 OFFLINE   MingL
MingL
  • 214 posts
Posted October 19 2004 - 06:26 PM
Don't see it now. Could you post the graph of the subs alone, mains alone and the sub+mains superimposed on the same graph? Its easier to see things this way sometimes.
#5 of 6 OFFLINE   Jeff_Wi
Jeff_Wi
  • 53 posts
Posted October 19 2004 - 06:50 PM
Ok, finally got the graph to work. As soon as I get a chance, I will do a comparison graph.
#6 of 6 OFFLINE   Mark Seaton
Mark Seaton
  • 600 posts
Posted October 20 2004 - 03:59 AM
First try setting the crossover for the mains up at ~80Hz. Then measure again.
Mark Seaton
Seaton Sound, Inc.
