Jump to content
Help! What Damage if They Have to Split the Cabinet?
  • Please log in to reply
11 replies to this topic
#1 of 12 OFFLINE   Arthur S
Arthur S
  • 2,572 posts
Posted September 13 2004 - 08:10 AM
My first HD TV is being delivered tomorrow (after only 15 years of waiting). If they have to split the cabinet to get it through the door to my apartment, should I expect to have any problems with the set because they split it? The set is a RPTV 65" Toshiba. I appreciate all comments. Thanks Artie
#2 of 12 OFFLINE   John S
John S
    Producer
  • 5,460 posts
Posted September 13 2004 - 09:04 AM
Uhhh, are you sure that is even an option? Most 65" CRT RPTV's, cannot be simply split up. So, in short I have my fingers crossed for you, that it fits through the door.
#3 of 12 OFFLINE   Arthur S
Arthur S
  • 2,572 posts
Posted September 13 2004 - 09:11 AM
Thanks for responding John. The specs for the 65 H 84 include the following statement. "split cabinet design". I found a link to the procedure and it is something that should only be done as a last resort, however, if the whole cabinet simply will not fit through a doorway, the set has been designed to be taken apart so that the 2 sections can fit through the door and then resassembled. I am praying that they do not have to split the cabinet. Thanks Artie
#4 of 12 OFFLINE   John S
John S
    Producer
  • 5,460 posts
Posted September 13 2004 - 09:56 AM
May the force be with you!!!! lol
#5 of 12 OFFLINE   Joe*C
Joe*C
    Extra
  • 17 posts
Posted September 13 2004 - 10:04 AM
Arthur, can you please post the link to the procedure? I plan on purchasing the 57HX94 when it's available, and the split cabinet design was a major selling point as I need to get it down to my basement. Thanks!
#6 of 12 OFFLINE   Arthur S
Arthur S
  • 2,572 posts
Posted September 13 2004 - 12:47 PM
Hi Joe I will look for the link as soon as things calm down. In the meantime, if I can't find the link, I can get a copy of the 2 page document and mail it to you. With a little luck I'll be able to find the link. Not to worry, I'll get it to you one way or another. Thanks Artie
#7 of 12 OFFLINE   Arthur S
Arthur S
  • 2,572 posts
Posted September 13 2004 - 01:17 PM
Good news Joe. Try this. Search split cabinet using the slowest search from the drop down menu. On the first page of results, look for a thread named "51 H 83 in 2 pieces". The thread was started by Mike Boniferro, and the link to the split cabinet is in one of the responses.
If you have a hard time finding the link I can Private Message you so that you will find the link for sure.
Artie
#8 of 12 OFFLINE   Joe*C
Joe*C
    Extra
  • 17 posts
Posted September 13 2004 - 03:15 PM
Artie, thanks for taking the time to dig up the link. Looks like I am in a "last resort" type of situation. Now it's my turn to pray and hope for the best. Then again, I have until November (when the 57HX94 is expected in stores) to think of an alternative solution. Thanks again. - Joe
#9 of 12 OFFLINE   Tyson Wetzel
Tyson Wetzel
  • 112 posts
Posted September 13 2004 - 06:31 PM
splitting the cabinet's no big deal, a few screws and a couple of plugs, very easy to put back together correctly
#10 of 12 OFFLINE   Tim Robbins
Tim Robbins
  • 34 posts
Posted September 13 2004 - 10:11 PM
Don't worry, this is no big deal at all. I have split many 57 and 65" toshiba's while moving them. Never saw any adverse effects...knock on particle wood. Tim
#11 of 12 OFFLINE   Arthur S
Arthur S
  • 2,572 posts
Posted September 14 2004 - 03:57 AM
Hallelujah!! They did not have to take my 65 H 84 apart to get it up a lot of stairs and into the apartment. They did have to take the apartment door off but that's nothing.
Waiting for the cable guy now. Tonight should be fun!!
Thanks to everyone who contributed to my thread.
Artie
#12 of 12 OFFLINE   Mike Boniferro
Mike Boniferro
  • 273 posts
Posted September 14 2004 - 01:17 PM
Glad to see that you had no problem getting the TV in!
I also counted myself as lucky for not having to take my 51" apart as I thought I would (hence the thread that I started last year about it).
Since that time I have taken apart close to 20 51", 57" and 65" TV's to get into some very tight places, and it is EXTREMELY easy, so anyone who is worried about it shouldn't be. The only thing to even think about is remembering to undo the clip that connects wires between the screen and the bottom portion. Posted Image
