Jump to content
Going to separate amps from receiver.
7 replies to this topic
#1 of 8 OFFLINE   Juan_T
Juan_T
  • 70 posts
Posted August 20 2004 - 10:44 AM
I have a Denon AVR-3802 with RF-3 Klipsch speakers.. If I get separate amps to drive these Speakers, instead of using the internal DENON receiver amp, will I hear a gigantic difference? Or are my speakers not good enough to take advantege of separate amps?
#2 of 8 OFFLINE   Wayne A. Pflughaupt
Wayne A. Pflughaupt
    Producer
  • 5,910 posts
Posted August 20 2004 - 02:36 PM
Ken,
It’s not so much that your Klipsch are “not good enough” as it’s just not necessary. The RF-3’s have an extremely high efficiency rating of 98dB @1 watt/1 meter. Most speakers have a figure in the 87-93 range, which means your speakers are about 6-10dB more efficient. Highly efficient speakers generate a lot of output for the power they’re given.
Considering that a 6dB increase in SPL requires double the amplifier power, using your Klipsch RF-3’s with the 3802 is the equivalent of driving speakers with a 89dB rating with a 250 watt amp! Or speakers with a 92dB rating with a 200 watt amp.
Wayne A. Pflughaupt
My Equipment List
“A nice mid-fi system,” according to an audiophile acquaintance.
My Tech / DIY Articles and Reviews
#3 of 8 OFFLINE   Juan_T
Juan_T
  • 70 posts
Posted August 20 2004 - 03:12 PM
Hi Wayne!
Thanks for your reply. I just thought, for some reason, that separate amps would provide "cleaner" power, thus making them sound better.
btw, My name is Juan!! Not Ken! Posted Image
#4 of 8 OFFLINE   Wayne A. Pflughaupt
Wayne A. Pflughaupt
    Producer
  • 5,910 posts
Posted August 20 2004 - 03:32 PM
:b :b It must be time for bed!
There’s always a chance of that, but if you want to try it be sure you get a liberal return policy.
Wayne A. Pflughaupt
My Equipment List
#5 of 8 OFFLINE   Chuck Bogie
Chuck Bogie
  • 397 posts
Posted August 26 2004 - 10:44 AM
I can hear a lot more difference from preamp circuitry than I can from the different amps... Case in point... Maggie MMGs driven by a Marantz 2230 sounded okay, but I worried about smoking the amp if I would turn it up.
My bud brought over a Pioneer SX1250... He's had it hooked up to a meter, and sez that it'll put out 250/side... Played nice and loud, but frankly, it sounded sorta harsh/compressed/lacking....
Plugged the preamp portion of the Marantz into the amp portion of the Pioneer. Not as nice as a friend's multi-thousand dollar system, but it sounded a lot better than the Pioneer by itself... Sounded MUCH more like the Marantz than it did like the Pioneer.
#6 of 8 OFFLINE   Yogi
Yogi
  • 1,741 posts
Posted August 26 2004 - 12:26 PM
I would agree with Wayne at this point. Although I must give him the benefit of doubt (because its way past his bed timePosted Image) in claiming that 6db gain equals doubling of power when it is 3db that equates to doubling of power. At 98db efficiency (of your speakers) you are essentially driving an average (89db) speaker with 800W of equivalent power (assuming 100W/ch from your Denon). So you practically already have an 800W/ch amp for your speakers. You are way ahead of most of us in terms of power requirements for your HT. So I don't think at this point adding a separate amp will get you much, if any, improvement in HT performance. Stick to the 3802 and buy some good software instead, or a good sub if you have none.
My two cents.
The truth is not out there but within you.
#7 of 8 OFFLINE   Laurence_C
Laurence_C
  • 172 posts
Posted August 26 2004 - 01:51 PM
Technically Wayne and Yogi are correct, but my ears told me different when I added my NAD amplifiers 218THX & S250 for my Klipsch 7.1 setup. Granted my Legend series towers are a bit bass oriented and still efficient, my Onkyo 105 w/ch receiver did not have the clarity, soundstage, crisp highs and clean power that these power amplifiers have. There is just a fullness to power amplifiers that a receiver can't produce. Juan, I suggest you mosey on over to the Klipsch website and search through their forums for more on this.Posted Image
#8 of 8 OFFLINE   Wayne A. Pflughaupt
Wayne A. Pflughaupt
    Producer
  • 5,910 posts
Posted August 26 2004 - 01:59 PM
Thanks for the correction, Yogi. I was looking at a chart that said “+ 6dB means about twice as loud (200% of the original SPL).” Which of course is not the same thing. :b
*yawn* Where's my nurse when I need her? Posted Image
Wayne A. Pflughaupt
My Equipment List
