Jump to content
Sign up for a free account!
Subwoofer basics.
5 replies to this topic
#1 of 6 Edwin K
Edwin K
  • 14 posts
Posted August 06 2004 - 05:07 PM
Asking this question here is like asking a neurosurgeon for help with a head cold. But I’m here; you’re here, what the heck.
I just got a very basic, very simple HT setup. Your basic $200 entry level deal. Simple, but I can’t begin to tell you how much better it is than stereo speakers. Scared the crap out of my nephew with a demo of Jurassic Park III.
My sub can be adjusted + or – 10 db. That’s my question. What am I adjusting? I find it very amusing when the floor vibrates, if that helps. I use this mainly for DVDs, and they are almost all action adventure blowing stuff up DVDs.
#2 of 6 SethH
SethH
  • 2,867 posts
Posted August 06 2004 - 05:18 PM
The idea is that your system is calibrated to a reference level which would be set with the sub at 0db. Then you have the option of raising or lowering the sub's gain by 10db. You can do a search on calibration to learn more about it. It involves a SPL (sound pressure level) meter and a calibration DVD.
#3 of 6 Edwin K
Edwin K
  • 14 posts
Posted August 06 2004 - 05:34 PM
Yikes. I'll look into it further. Till then I'll leave it at 0db. I assume I can replace it with a powered sub some day? I may buy my next system a component at a time.
#4 of 6 Wayne A. Pflughaupt
Wayne A. Pflughaupt
    Producer
  • 5,910 posts
Posted August 07 2004 - 05:35 AM
That usually isn’t possible with an entry-level system. With them typically the sub connects with speaker wire to the main unit – i.e., the sub isn’t providing it’s own power, the main unit is. A powered sub needs a line-level signal from an RCA jack.
Wayne A. Pflughaupt
My Equipment List
“A nice mid-fi system,” according to an audiophile acquaintance.
My Tech / DIY Articles and Reviews
#5 of 6 Edwin K
Edwin K
  • 14 posts
Posted August 07 2004 - 06:17 AM
I wondered about that. I did find a powered sub that has both line-level and speaker-level inputs. I still plan on stair stepping my next system; buying one thing at a time. I may start with a better center channel, then fronts, surrounds, so on. I could hold off on the powered sub until I upgrade the receiver. Thanks for the information.
#6 of 6 Stephen Houdek
Stephen Houdek
  • 325 posts
Posted August 08 2004 - 01:32 AM
You're probably better off buying a better processor first.
Not sure what your entry level system came with, but that will allow you some more flexibility when you want to upgrade your speakers.
