RodN
- May 9, 2004
Hi,
I was wondering what peoples thoughts were on the difference in quality between professional audio gear (like Crown amps, Alesis etc vs 'regular' consumer audio stuff (like Marantz, Rotel etc).
There seems to be a lot of high wattage amps on Ebay and elsewhere from the Pro Audio side that are quite cheap and I was wondering if they were worth it. I was considering buying an Alesis Matica 900 amp to power my speakers, but just don't know if these sorts of amps are appropriate for use in the home.
Cheers
Rod
Cheers
Rod
