Jump to content
I need a cooling fan.. how do I make one?
17 replies to this topic
#1 of 18 OFFLINE   Jeff:L
Jeff:L
  • 12 posts
Posted July 02 2004 - 07:38 AM
Hello, I need a cooling fan for my cabinet to keep my receiver cooler. I went to radio shack, but they dont sell AC fans that have the plug on it already. I dont know how to connect a plug, can anyone help? Would it be easier to connect a computer fan? The problem with that is that those are DC right? Help!
#2 of 18 OFFLINE   Darren_T
Darren_T
  • 494 posts
Posted July 02 2004 - 07:47 AM
Find yourself a fan at RadioShack that is compatible with 110v/120v AC. Just connect a common lamp cord (with plug) to the leads with proper connectors and whalla! You have a fan. If your receiver has a switchable power supply plug on it you can plug the fan into the receiver and have auto on/off for free Posted Image
#3 of 18 OFFLINE   Drew_W
Drew_W
  • 1,718 posts
Posted July 02 2004 - 10:02 AM
Use a universal adapter. That'll let you change voltage from 3~12V and therefore vary the speed of the fan. Then use a computer fan hot-wired to that. Real simple.
I gave up on tracking my collection and actually started watching what I have.
#4 of 18 OFFLINE   Jeff:L
Jeff:L
  • 12 posts
Posted July 02 2004 - 10:56 AM
If I buy a AC fan & lamp cord, does it matter which wire goes to which? I notice that AC plugs do not seem to have a positive & negative wire? Sorry, but what is a universal adapter?
#5 of 18 OFFLINE   Drew_W
Drew_W
  • 1,718 posts
Posted July 02 2004 - 11:01 AM
One of those things you buy at Radio Shack so you don't have to use batteries for your CD Player/Portable TV/whatever else...
Reversing the polarity changes the direction of the fan...
#6 of 18 OFFLINE   Joey Skinner
Joey Skinner
  • 339 posts
Posted July 02 2004 - 11:23 AM
On an AC fan polarity doesn't matter. For a cord you can buy a cheap extension cord and cut off the female end, strip the wire ends and solder them to your fan leads, using heat shrink for insulation. You can also scavenge a cord from any dead electical device.
#7 of 18 OFFLINE   Wayne A. Pflughaupt
Wayne A. Pflughaupt
    Producer
  • 5,937 posts
  • Real Name:Wayne
  • LocationKaty, TX
Posted July 02 2004 - 12:26 PM
Not for A/C; there is no polarity for A/C. Jeff, what Drew was talking about is an A/C adapter. It would let you use a DC fan. The adapter can plug into the switched outlet of your receiver. Regards, Wayne A. Pflughaupt
My Equipment List
“A nice mid-fi system,” according to an audiophile acquaintance.
My Tech / DIY Articles and Reviews
#8 of 18 OFFLINE   Jeff:L
Jeff:L
  • 12 posts
Posted July 05 2004 - 10:09 AM
Thanks for the replies guys! I got a 120 VAC fan from radio shack & a AC plug to connect it to an AC outlet. Question is, can I plug this 120 VAC fan into the switched outlet on my Harman Kardon?
#9 of 18 OFFLINE   Drew_W
Drew_W
  • 1,718 posts
Posted July 05 2004 - 10:15 AM
Yes.
#10 of 18 OFFLINE   Jeff:L
Jeff:L
  • 12 posts
Posted July 05 2004 - 01:27 PM
Thanks for the reply Drew. Actually looking at the box, it says that it is a 115 VAC.. can I plug this into the receiver switched outlet too even though its now 120 VAC? Probably sounds like a dumb question... sorry.
#11 of 18 OFFLINE   Mark Shannon
Mark Shannon
  • 1,991 posts
Posted July 05 2004 - 03:38 PM
It would work, but the fan would probably be a bit too overpowered and eventually blow.
#12 of 18 OFFLINE   Darren_T
Darren_T
  • 494 posts
Posted July 06 2004 - 03:04 AM
The fan won't blow... 115 VAC and 120VAC are the same thing. Remember when they used to call it 110 VAC? It's just common household voltage.
#13 of 18 OFFLINE   Jeff:L
Jeff:L
  • 12 posts
Posted July 09 2004 - 07:59 PM
ok guys I just woired up this radio shack fan & boy is it loud! it has a loud whirling noise! I have not plugged it into my receiver yet, but I know that it will be quite loud. Is there anything that you guys can suggest? Is there a quieter fan that I can buy? I was thinking about using the DC fan a universal adapter, but the only problem is that the universal adapter's plug is an adapter & so it has one of those big box type of plugs which will not plug into my reciever... Posted Image help please.
#14 of 18 OFFLINE   Wayne A. Pflughaupt
Wayne A. Pflughaupt
    Producer
  • 5,937 posts
  • Real Name:Wayne
  • LocationKaty, TX
Posted July 10 2004 - 04:13 AM
Jeff, I’d return the AC fan and get a DC fan, along with an AC adapter that has different voltage settings. If you get a 12v fan and run it at say, 7.5 or 6v it will slow it down considerably. Regards, Wayne A. Pflughaupt
My Equipment List
#15 of 18 OFFLINE   Darren_T
Darren_T
  • 494 posts
Posted July 10 2004 - 04:31 AM
Isn't this going to be a cabinet cooling fan? Chances are you won't hear a thing in the back of your cabinet... Mine wasn't noticeable when I had one. Give it a test before you return it.
#16 of 18 OFFLINE   Owen Bartley
Owen Bartley
  • 486 posts
Posted July 11 2004 - 06:06 AM
Or you could go to a computer store and pick up a "Stealth" fan, I think Vantec might make them.
#17 of 18 OFFLINE   Jeff:L
Jeff:L
  • 12 posts
Posted July 11 2004 - 05:58 PM
I went & got a Vantec Stealth fan, and it is much quieter, although you can still hear it when there is no music. But that is when the adapter is set to 12V. Can anyone tell me, If I want to hook up two 12V fans to one AC/DC universal adapter, is 1200 ma big enough? Also, will hooking up two 12 V fans require a separate adapter for each fan, or do I need a 24 V adapter? or does it not matter how many fans I hook up to the adapter as long as all the fans are 12 Volt?
#18 of 18 OFFLINE   Owen Bartley
Owen Bartley
  • 486 posts
Posted July 12 2004 - 01:25 AM
Not too sure about the adapter, but check out this thread where Mark put 2 fans into a beautiful new equipment stand, and wired them in series to run them quieter... might be an idea.
