Jump to content
What HDTV Antenna are you using?
23 replies to this topic
#1 of 24 OFFLINE   SteveLeach
SteveLeach
  • 159 posts
Posted June 21 2004 - 05:53 AM
I'm trying to get a sense of what HDTV antenna's are better than others. So if you could respond with which one you are using or have used and your experiance, that would be great.
Never give up! Never Surrender!
--Cmdr Taggart
#2 of 24 OFFLINE   SteveLeach
SteveLeach
  • 159 posts
--Cmdr Taggart
#3 of 24 OFFLINE   Don_Berg
Don_Berg
  • 931 posts
Posted June 21 2004 - 06:49 AM
I tried a bunch of models and the best (and bargain price) I found was the Channel Master model 4221 UHF 4x bowtie antenna. By the way there is no "HDTV" antenna, they are broadcast on the same UHF (and a few VHF) bands so the same antennas for analog are used for digital channels. Most digital/HD channels are UHF so its important to get one designed for good reception on HF which the 4221 is.
#4 of 24 OFFLINE   Robert_J
Robert_J
    Lead Actor
  • 8,184 posts
  • Real Name:Robert
  • LocationMississippi
Posted June 21 2004 - 07:05 AM
What may work for Don, may not work for you. Every situation is different (almost). First you should go to AntennaWeb to find the type (UHF, VHF or both) and size antenna you need. It could be anything from a Silver Sensor that sits on your TV to a ChannelMaster 4228 (about 4 feet wide) mounted on your roof.
The only thing that is common with antennas is that Terk is over priced for the performance you get out of it. An antenna's performance is related to it's design so stay away from stealth models of the ones that clip on your satellite dish.
-Robert
#5 of 24 OFFLINE   SteveLeach
SteveLeach
  • 159 posts
Posted June 21 2004 - 10:19 AM
Thanks for the information. Yes, I knew HDTV is mostly all broadcast over UHF, but wanted to be specific in the subject. I've visited antennaweb a few times. But I find their information to be pretty general. Don't get me wrong they provided the information about what channels are available and how far away they are, like this: These ABC, NBC, CBS, UPN & PBS are ~10 miles away, then there is FOX which is ~30 miles away. If it helps, I live in the Seattle area. Which have plenty of rolling hills and trees everywhere. But I was hoping to avoid the buy, try, return and repeat method of actually selecting an antenna. The information about TERK being over priced for the performance is what I'm looking for.
--Cmdr Taggart
#6 of 24 OFFLINE   Don_Berg
Don_Berg
  • 931 posts
Posted June 21 2004 - 06:09 PM
Are all the stations in the same general direction, what is the compass direction for them? The 10 mile away stations should be easy to receive with almost anything (except maybe a Terk ) but the 30mile away station may require a decent outdoor antenna like the CM4221. Whats your elevation and are there obstructions (hills,trees,etc) in the direction of the stations?
#7 of 24 OFFLINE   Hank_P
Hank_P
  • 282 posts
Posted June 22 2004 - 01:10 AM
Robert is correct in what may work for others, may not fit your need. I have two OTA HD boxes. The first box I received, I connect a Radio Shack Double Bowtie to it and it worked beautifully. I later picked up another OTA HD box for a newly purchased big screen for the bedroom. This time I had the Zenith Silver Sensor, and it just didn't work for me. The Zenith has been praised by many on this board, but it didn't work in my situation, I purchased a second RS Double and all it beautiful in my world. The Zenith couldn't pull in one station, and the colors where not as 'bright', kind of dull/washed out. On a side note, I did try a channel master, but it was overkill since I was pretty close to the towers.
#8 of 24 OFFLINE   Patrick Sun
Patrick Sun
    Studio Mogul
  • 38,028 posts
Posted June 22 2004 - 02:25 AM
I use a combination of a RS Double Bowtie UHF antenna and a signal booster. I live about 20 miles from the towers.
"Jee-sus, it's like Iwo Jima out there" - Roger Sterling on "Mad Men"
Patcave | 2006 Films | 2007 Films | Flickr | Comic-Con 2012 | Dragon*Con 2012
#9 of 24 OFFLINE   RobertR
RobertR
    Lead Actor
  • 9,565 posts
Posted June 22 2004 - 04:15 AM
I use a Channel Master 4248 UHF Antenna. Works perfectly. I'm about 20 miles south of the Mt. Wilson TV transmitters.
#10 of 24 OFFLINE   Cameron Yee
Cameron Yee
    Executive Producer
  • 10,725 posts
  • Real Name:Cameron Yee
  • LocationSince 2006
Posted June 22 2004 - 04:35 AM
I have $20 Radio Shack UHF mounted on my roof. My reception is very strong (less than 10 miles from the towers). I could have gotten away with an indoor (I tried the Jensen TV940 and RS double bowtie, both of which I'm looking to sell), but a bus line goes right by my house and I live on a busy traffic corner, so the traffic (and in particular the big reflective sides of the buses) were causing signal interference at ground level.
#11 of 24 OFFLINE   SteveLeach
SteveLeach
  • 159 posts
Posted June 22 2004 - 06:03 AM
Hey, thanks all for the information. Don, the stations are tightly grouped from 225° to 236° compass orientation from my place. At least I'll be able to point to all them with out needing a rotor. Because of the hills and trees surrounding my place, it seems my best bet would be the roof mounted type. I'll take a trip to RS tonight and see what they have.
--Cmdr Taggart
#12 of 24 OFFLINE   Don_Berg
Don_Berg
  • 931 posts
Posted June 22 2004 - 08:54 AM
Avoid Radio Shack - go for a good quality Channel Master or Winegard UHF antenna. With that tight grouping, you could use any high gain type. You might need a tall mast to get over the trees.
#13 of 24 OFFLINE   Don_Berg
Don_Berg
  • 931 posts
#14 of 24 OFFLINE   Robert_J
Robert_J
    Lead Actor
  • 8,184 posts
  • Real Name:Robert
-Robert
#15 of 24 OFFLINE   SteveLeach
SteveLeach
  • 159 posts
--Cmdr Taggart
#16 of 24 OFFLINE   Don_Berg
Don_Berg
  • 931 posts
#17 of 24 OFFLINE   Hank_P
Hank_P
  • 282 posts
#18 of 24 OFFLINE   Patrick Sun
Patrick Sun
    Studio Mogul
  • 38,028 posts
#19 of 24 OFFLINE   RobertR
RobertR
    Lead Actor
  • 9,565 posts
#20 of 24 OFFLINE   Cameron Yee
Cameron Yee
    Executive Producer
  • 10,725 posts
