Jump to content
The Best Remote Control for my HT
17 replies to this topic
#1 of 18 OFFLINE   Omard.
Omard.
  • 200 posts
Posted April 16 2004 - 07:02 AM
I need some help finding a remote that will control all of my equipment. I have listed my equipment below.
1. Tivo Series 2
2. Dish Network 811
3. Voom STB
4. Sony Projection TV
5. Onkyo 601 Receiver
6. Onkyo 301 DVD Player
I want something that will control all of these and be easy to use for the wife. Thanks for the help.
#2 of 18 OFFLINE   Erik*R
Erik*R
  • 41 posts
Posted April 16 2004 - 07:14 AM
you have the perfect remote control already.. its called "the wife" Posted Image
actually I would like to know if there is one control that works for all the devices above.. I have a similar setup with equipment that has both IR and RF remotes and havent found a remote that works well with both IR/RF.
thanks guys.
#3 of 18 OFFLINE   Omard.
Omard.
  • 200 posts
Posted April 16 2004 - 07:25 AM
The wife is the problem. She get confused with all the remotes and get pissed when she hears one thing but the tv shows something totally different.
#4 of 18 OFFLINE   Eric Samonte
Eric Samonte
  • 1,325 posts
Posted April 16 2004 - 07:44 AM
Have u looked at a Pronto PRO? It will do IR and RF withan optional add-on. Though u should be aware it will take much of ur time programming it to ur liking, not to mention one has to be a tad bit computer savvy.
#5 of 18 OFFLINE   Lev-S
Lev-S
  • 324 posts
Posted April 16 2004 - 04:47 PM
Harmony SST-659...Posted Image
My DVDs
Homer: So, Mr. Malloy, it seems that the cat has been caught by the very person who was trying to catch him.
Skinner: How ironic.
#6 of 18 OFFLINE   Byron_T
Byron_T
    Extra
  • 24 posts
Posted April 16 2004 - 04:58 PM
I second the vote for the Harmony SST-659. I have one and it controls all of my equipment with no problems.
If the facts don't fit the theory, change the facts.
Albert Einstein
#7 of 18 OFFLINE   Shane Martin
Shane Martin
    Producer
  • 6,017 posts
Posted April 17 2004 - 12:51 AM
I have a Pronto. A friend has a Harmony. He said that the Harmony is pretty easy to program and he likes it(last I checked).
It will all depend on whether you like a touch screen or hard buttons and then decide which of those 2 you would like. I bought my father in law a Mx500 HT master remote and I didn't like it one bit.
#8 of 18 OFFLINE   Brian Schucher
Brian Schucher
  • 704 posts
Posted April 20 2004 - 01:06 AM
Shane, what did you not like about the 500? If it was its programing, the MX700 makes it a non-issue..
#9 of 18 OFFLINE   Scott Merryfield
Scott Merryfield
    Executive Producer
  • 10,612 posts
  • LocationMichigan
Posted April 20 2004 - 01:25 AM
I'll also recommend the Harmony SST-659 or newer SST-688. I own the 659 and love it. My wife likes it a lot better than our previous universal remote -- a Marantz RC2000 MKII. It's very intuitive to use. Even my technology-challenged parents were able to figure it out without any instructions when they stayed with us over the holidays.
The SST-659 easily replaced all the functions of seven remotes in my system. It is pretty easy to setup, and the company has very good customer support if you have problems configuring the remote.
#10 of 18 OFFLINE   Qui-Gon John
Qui-Gon John
    Producer
  • 3,527 posts
Posted April 20 2004 - 04:34 AM
I love my MX-500, so if you also have to mix in RF, then the MX-700 is probably a great choice, although a little pricey, you can find it at surf remote for $349.95 and they have an Open box unit right now for $193.95
#11 of 18 OFFLINE   Stephen Tu
Stephen Tu
  • 1,573 posts
Posted April 20 2004 - 06:38 AM
My vote is for the MX-500/MX-700, or maybe the new URC-200 from the same company. Harmony would be my 2nd choice; I greatly prefer the key layout on the HTM remotes.
Read the reviews of all over at www.remotecentral.com
If you need RF capability, then MX-600/MX-800, or URC-200 + add/on base station, depending on how much macro capability you need.
#12 of 18 OFFLINE   Shane Martin
Shane Martin
    Producer
  • 6,017 posts
Posted April 20 2004 - 08:47 AM
I didn't care for the layout myself. Keep in mind I like the touch screen as well.
#13 of 18 OFFLINE   Ted Lee
Ted Lee
    Lead Actor
  • 8,399 posts
Posted April 21 2004 - 07:26 AM
mx-500 is a godsend. i have two myself and have referred at least three friends to it as well. do a search here and see how many times that thing has been recommended. for a hundred bucks, it's a steal.
btw, on a completely side note, how do you like voom? how's the hd quality and programming variety???
#14 of 18 OFFLINE   Ronnie Rose
Ronnie Rose
  • 2 posts
Posted April 21 2004 - 08:56 AM
Anyone able to use the remotes listed and a Dish 921 sat receiver and a Runco projector?
#15 of 18 OFFLINE   Ted Lee
Ted Lee
    Lead Actor
  • 8,399 posts
Posted April 21 2004 - 10:25 AM
ronnie -
all the remotes mentioned here are "learning" remotes. so, they shouldn't have any issues controlling any other remote.
cruise over to remotecentral.com - more info then you ever wanted to know about remotes...
#16 of 18 OFFLINE   Qui-Gon John
Qui-Gon John
    Producer
  • 3,527 posts
Posted April 21 2004 - 11:18 AM
Ditto. I used to think that Universal Remotes were a waste because they couldn't replace all the features on the OEM remote. And that was true for the ones I had used, the so-called Universal Remotes that came with my RPTV or with my cable box. But the MX-500 has truly replaced all my other remotes in both my living room and master bedroom. (and I was able to program all those devices onto the one remote).
#17 of 18 OFFLINE   Chris_Cur
Chris_Cur
  • 47 posts
Posted April 21 2004 - 12:37 PM
MX-500 for me as well... I've got two now. My old Pronto is in storage, except when I want to teach my MX-500 discrete codes.
#18 of 18 OFFLINE   Ted Lee
Ted Lee
    Lead Actor
  • 8,399 posts
Posted April 21 2004 - 12:38 PM
heh...almost forgot about my own mini-faq.
http://www.hometheat....901#post562901
Forum Nav Content I Follow
