Jump to content
Help with ZIRE palmpilot.....
  • Please log in to reply
1 reply to this topic
#1 of 2 OFFLINE   kevin_tomb
kevin_tomb
  • 148 posts
Posted April 04 2004 - 01:41 AM
I had to reset all the initial settings on my palmpilot, and being tired, I accidentally messed up the screen stylus settings. Now when I tap on icons on screen, they dont respond correctly. I have to his stylus off center of Icons. MY question is: HOW do I get back to those initial set up preferences. I cant seem to find it anywhere. Im talking about the initial setup, not the preferences.
#2 of 2 OFFLINE   Lee L
Lee L
  • 868 posts
Posted April 05 2004 - 03:04 AM
You need to go to preferences, then at the top right, where it has a down arrow and probably the word GENERAL, tap on that and select DIGITIZER. That should do it.
Revenge is like serving cold cuts-
Tony Soprano
