Jump to content
sony camcorder NEED HELP QUICK!
No replies to this topic
#1 of 1 OFFLINE   kevin_tomb
kevin_tomb
  • 148 posts
Posted March 30 2004 - 07:56 AM
Im not sure if this is the right forum to ask this in, but I need help with my sony dcr-trv340 camcorder. It keeps having the moisture indicator pop up, and it wont reset. I had this before and it reset after I hit the reset button under the LCD display. There is NO moisture in camera, its just going off for no real reason. Like a false alarm. Its still under warranty, but I need it fixed FAST, cant wait 2 weeks for it to be sent out. Has anyone heard of a fix for this problem?....I have heard its common with the sony camcorders, and it might be a faulty sensor problem. I am an electronic tech, but I dont wanna take anything apart on it and risk voiding the warranty etc. Any help will be GREATLY appreciated..
