ScottR
- Apr 1, 2000
Can those of you with the Seasons 1 and 2 set of Scooby Doo check your Disc One for me? Mine is very jittery, especially when you pause or fast foward....but only on Disc ONe....can you check yours and report back so I know if mine is faulty? Thanks.
To clarify.....when you pause, you can see part of the next frame, and everything is blurry and jittery. You can't see it during normal play.
