RyanPitt
- Jan 21, 2004
Afternoon Everyone, I have a Pany E60 and I am just wondering what the best settings would be to record stuff. TV shows I really dont care about I record those at the lowest quality most of the time anyways. My concern is my DV tapes. I am using the firewire connection with DVD-R and just wondering if I should use Flexible Record to set to like 1 hour and 2 minutes because most of the tapes let you go over by a little. Or should I be using DVD-Ram? I am not really sure
Ryan
Ryan
