X-over for SVS and Paradigm Moniter 7's? (1 Viewer)
Jonathan_E
Hello,
My new SVS 20-39 pci will be arriving on Monday and I was curious if anyone had any suggestions for what I should set the cross-over on my Denon AVR 3803 at. I have Paradigm Monitor 7's for the mains, a CC-370 for the center, and some cheap sonys for surround that will be replaced with mini monitors when the funds are available.
If I remember correctly, the 3803 allows you to adjust the cross-over by 20 hertz intervals between 40 to 120 hertz. So, I was just curious if there was anyone out there with a similar set up that might have some recommendations.
Jonathan
Mike_Skeway
If you can or want to do a different setting for each. You could set the Monitor 7s at 70Hz, the CC-370 at 120Hz, and the Mini Monitors to 80Hz.
Or just set them all to 80Hz. :)
Also, disable the crossover on the sub or turn it to the highest setting.
acinstallation172
