Jump to content
Sign up for a free account!
DVD Player Problem....???
6 replies to this topic
#1 of 7 Jeremy Scott
Jeremy Scott
  • 292 posts
Posted February 13 2004 - 04:58 PM
a buddy of mine gave me his friends dvd player to look at. for some reason, when you play a dvd, the picture is up about 3 inches from the bottom of the screen and it is in black and white.
i think it is a cheap player, the maker is Norvent.
what could cause this to happen?
#2 of 7 Jeremy Scott
Jeremy Scott
  • 292 posts
Posted February 14 2004 - 03:05 PM
anyone?
#3 of 7 Jack Briggs
Jack Briggs
    Executive Producer
  • 16,725 posts
Posted February 15 2004 - 06:50 AM
You don't have the player connected to a VCR, do you?
#4 of 7 Don_Berg
Don_Berg
  • 931 posts
Posted February 15 2004 - 08:24 AM
Yes that might occur due to macrovision if you are not connecting the DVD player's output directly to the TV's video input with nothing in-between.
#5 of 7 Jeremy Scott
Jeremy Scott
  • 292 posts
Posted February 15 2004 - 12:32 PM
the inputs are going directly from the dvd player into my jvc tv.
#6 of 7 Jack Briggs
Jack Briggs
    Executive Producer
  • 16,725 posts
Posted February 16 2004 - 05:14 AM
Then what kind of connection is it — S-video? Component video? Composite video/audio? If component, is it connected correctly?
Otherwise, the player simply may be on the fritz. Those ultra-cheap things are not noted for their ruggedness and longevity (DVD players as a whole are rather delicate and prone to short lifespans, and all that goes double for the $40 specials).
#7 of 7 Don_Berg
Don_Berg
  • 931 posts
Posted February 16 2004 - 06:10 AM
With component video, if only the Y connection is made (Green connector) and the other two (red and blue) are bad connections that would result in a B/W picture only. Check the connections and try a new component cable.
