Nathan_F
I need to replace an old video card in, well, an old computer. I don't need anything too fancy, as I will probably be CPU-limited (733 PIII). I am looking at GeForce FX5200 (non-ultra) cards and see many with a heat sink and some with a fan. Will the heat sink cool as well as a fan? All of the higher-end cards have fans, so my first thought is no. But you're also deleting a moving part from the equation which is advantageous from a longevity perspective.
Thanks!
Nathan
Thanks!
Nathan
