GregBe
- Jul 9, 2003
It is my understanding that there are some serious bass management issues with DVD Audio. I have my sub hooked up to my main channels along with satellite speakers through the speaker level inputs, so in essence I have full range main speakers down to 24Hz. I have a small center channel and small surrounds that aren't capable of anything less than 80 Hz (and probably not more that 100 Hz at a good db level). My JVC DVD changer is DVD-Audio capable, and I already have 6 good Monster cables that I am not using. Are DVD-Audio mixed in multichannel to support this type of system, or is there sub 80Hz bass outside of the main channels?
If not, can you listen to DVD-Audio in stereo mode, and if so is 2 channel stereo mode not as good as multichannel, or is that preferable to some?
Greg
Greg
