Jump to content
Projector Mount and Drywall Question
13 replies to this topic
#1 of 14 OFFLINE   Torgny Nilsson
Torgny Nilsson
  • 255 posts
Posted January 14 2004 - 08:57 AM
Can someone tell me whether I can attach my projector to my drywall ceiling using molybolts rather than attaching the mount directly to the studs as it says in my mount manual? I don't have studs where I need to install the projector and I don't have an attic that I can access to reinforce the ceiling above the projector.
Has anyone done the same thing? The projector is only 6.8 lbs (plus the weight of the mount) and I assume I will be okay as long as I use molybolts that can hold up to 30 to 50 lbs.
Thanks.
#2 of 14 OFFLINE   Erik Farstad
Erik Farstad
  • 560 posts
Posted January 14 2004 - 09:08 AM
Yes, you'll be fine using moly's....just make sure you use the appropriate size and depth for your application.
E
#3 of 14 OFFLINE   Darren{Moo}
Darren{Moo}
    Extra
  • 23 posts
Posted January 15 2004 - 08:32 AM
From the been there, done that department, my advice would be to cut the drywall and install a framing member. Drywall repair cheap....Projector repair expensive.....
YMMV
Sometimes to much to drink is just barely enough... Mark Twain
#4 of 14 OFFLINE   Ron-P
Ron-P
    Producer
  • 6,283 posts
  • Real Name:Ron
Posted January 15 2004 - 10:33 AM
Why not build a small mounting plate that will span the distance between two joists. You can lag-screw the plate to the joists and then mount the PJ to the plate. That's what I did.
Posted Image
It may not look as clean as a direct mount to the drywall, but it's 100x more solid.
Peace Out~Posted Image
You have all the weapons you need...Now fight!
#5 of 14 OFFLINE   Erik Farstad
Erik Farstad
  • 560 posts
Posted January 15 2004 - 10:49 AM
Duh...great point Ron...I too did the same thing, built a mounting plate. :b But I guess I was too focused on answering Torgny's question, I missed the obvious! LOL....
#6 of 14 OFFLINE   Torgny Nilsson
Torgny Nilsson
  • 255 posts
Posted January 19 2004 - 10:39 AM
I decided to take your collective advice and am building a mounting plate. More work, but more peace of mind as you have mentioned. Thanks for the help.
#7 of 14 OFFLINE   Randy Emery
Randy Emery
  • 13 posts
Posted January 20 2004 - 01:26 AM
message deleted
Randy Emery
#8 of 14 OFFLINE   Shane Burton
Shane Burton
    Extra
  • 23 posts
Posted January 20 2004 - 01:32 AM
Drywall is more than sufficient, as long as you use a mounting plate that spreads the load out.
Shane
#9 of 14 OFFLINE   Randy Emery
Randy Emery
  • 13 posts
Posted January 20 2004 - 01:38 AM
Yes, the drywall would not particiate structurally
Randy Emery
#10 of 14 OFFLINE   marc_manny
marc_manny
  • 55 posts
Posted January 20 2004 - 02:20 AM
Go to Home Depot and buy at ceiling fan mount. They have ones for new construction and ones for remodeling. You want the one for remodeling, so basically you cut out a small hole in the ceiling and then fit the entire unit up into it. There are expansion nuts on each side that you screw (kind of like a shower rod) to tighten between the studs. Then you can just secure the projector to the ceiling box. They are rated for like 30 pounds or more.
Marc
#11 of 14 OFFLINE   Ron-P
Ron-P
    Producer
  • 6,283 posts
  • Real Name:Ron
Posted January 20 2004 - 03:32 AM
Marc, do you know if those mounts are hollow up the center and have a large enough diameter to allow cables up through? Make for a nice clean look if so.
#12 of 14 OFFLINE   CRyan
CRyan
  • 1,244 posts
Posted January 20 2004 - 04:53 AM
Hey Ron. They are not big enough for a DVI cable. However, they can be cut faily easily to accomodate several sets of cables. I was thinking of using these myself until I changed my mounting plan. Very easy, especially if you have access above the ceiling.
C. Ryan
#13 of 14 OFFLINE   marc_manny
marc_manny
  • 55 posts
Posted January 20 2004 - 06:11 AM
Hey Ron,
They have nickel size holes (the ones I have used), so like C.Ryan said you probably won't get a DVI cable through it. It would be worth while to take a look and see if they have any with bigger holes, or maybe you could cut enough out for a DVI connector to fit through without loosing structual integrity(sp?).
They are definately easier if you have access to above the ceiling, but it can be done from below also.
Marc
#14 of 14 OFFLINE   Jason_Reynolds
Jason_Reynolds
  • 26 posts
Posted January 21 2004 - 06:06 AM
Use the adaptor plate with dry-wall cutout......
