Jump to content
Sign up for a free account!
Do Direct TV and Dish Network point same spot?
5 replies to this topic
#1 of 6 florence franks
florence franks
  • 134 posts
Posted January 06 2004 - 03:06 PM
Getting tired of mini pauses once a hour with my dish network and thinking of taking advantage of free direct tv install. But I dont have much room to work with, does Direct tv point in same direction, SE?
thanks
#2 of 6 Trevor_J
Trevor_J
  • 279 posts
Posted January 06 2004 - 05:07 PM
You can use one dish for both networks if you point your dish at DirecTV's satellite and then tie an LNB (using zip ties) to the left side of the DirecTV LNB. I'm pretty sure it's the left side but I'll have to check for you when it's light outside.
"Never underestimate the Powah of the Dahk Syhde..."
#3 of 6 Robert_J
Robert_J
    Lead Actor
  • 8,053 posts
  • Real Name:Robert
  • LocationMississippi
Posted January 07 2004 - 12:05 AM
Which receiver are you using? This is not a normal problem.
If you have a Dish500 dish, you are pointed at satellite locations 110 and 119. DirecTV core programming is at location 101, just to the left of where you are pointing. If you decide to switch, I recommend getting a Phase III dish with your DirecTV system. It points at 101, 110 and 119. You will get a few extra channels now but if you decide to upgrade to HD, you will already have the required dish. I also recommend spending a few dollars and getting the DirecTivo. It's the best piece of equipment that I have ever purchased.
-Robert
#4 of 6 florence franks
florence franks
  • 134 posts
Posted January 07 2004 - 03:15 PM
I am using very first HD capable reciever came out for dish. its oldy. I think its HD6000? I put up with these mini breaks/pauses for over year as I've repeated be told same useless information, line of sight, cables, etc. And last 4 months it just getting more frequent. There is shed to left of my setup outside my apartment being reason why I asked as I cant point much more to left.
thanks for info.
#5 of 6 Robert_J
Robert_J
    Lead Actor
  • 8,053 posts
  • Real Name:Robert
Posted January 08 2004 - 12:44 AM
Go to Wal-Mart and get a $5 compass. Find the dish pointing coordinates here and you will be able to see if you can get the 101 satellite. Only use the coordinates for the small dish.
Actually the first HD Dish receiver was the model 5000. I had the 6000 before I switched back to DirecTV. I never had any problems like you describe.
-Robert
#6 of 6 Jim-L
Jim-L
  • 13 posts
Posted January 08 2004 - 03:49 AM
I've got the new 811 and am very happy.
Back to Blu-ray, DVD, LD, Tivo, Satellite and Other Playback Devices
Forum Nav Content I Follow
