Jump to content
Noob-need help with cables
1 reply to this topic
#1 of 2 OFFLINE   JohnRan
JohnRan
  • 1 posts
Posted December 21 2003 - 09:26 AM
this is a good forum-but I am confused. I have an Onkyo HT760-my question-how do I hook up? -I have an older VCR,basic cable,TV w/componet inputs- I want to use the VCR to playback movies(TV sound would be ok,but would prefer to use home stereo speakers which will be connected to the "B" setting on the receiver.I have (1) componet cable now and an optical cable- I was told to connect the DVD player to the TV with the componet cable and to connect the DVD player to the receiver with the optical cable. The cable(no convertor)would go to VCR and connect to TV from there.For sound,run RCA pins from VCR to aux. on receiver.Will this work? There will be no game systems connected to this.Thanks in advance.
#2 of 2 OFFLINE   ChrisWiggles
ChrisWiggles
    Producer
  • 4,791 posts
Posted December 21 2003 - 11:50 AM
That sounds like one way to set it up. It should work that way just fine. In fact my stereo is set up in the same fashion, except sans the DVD player. (in the tv room mind you).
