Todd Alexander
- May 1, 2003
I bought an Onkyo TX-NR900 and it's great. Trouble is that all the sound mosed sound awesoem and I trully can't tell the difference between them. For example, Lord of the Ringd Extended version has the DTS 6.1 Discrete sound setting, the end all of codecs, right? Sounds great yes, but I really don't know if it is better than the pro logic II setting.
Without getting too technical, wold someone which ones are 'supposed' to be the better sounding modes? Please rate these from "best" to "worse" if possible. I'm trying to keep it simple.
DTS
DTS-ES Discrete/Matrix 6.1
Dolby Digital
Dolby Digital EX
DTS
Dolby Digital
Dolby Digital EX
