Jump to content
My 85L Vented Shiva Project Questions
25 replies to this topic
#1 of 26 OFFLINE   Gerry S
Gerry S
  • 122 posts
Posted December 09 2003 - 03:13 PM
I am making good progress on building my subwoofer, and had a question concerning mounting the plate amp.
I'd like to mount the amp in the cabinet, but don't want to do this if it will have a negative effect on the performance of the sub. The plans themselves make no mention (good or bad) of mounting the amp, so I thought I would see if anyone could give me the thumbs up or down concerning mounting the amp in the cabinet. If I do mount the amp it looks like it must go in the front panel(front according to the plans).
Thanks.
#2 of 26 OFFLINE   Brian Bunge
Brian Bunge
    Producer
  • 3,719 posts
Posted December 09 2003 - 04:05 PM
Gerry,
I've mounted the amp to the back of similar subs many times. I usually just cut out a small "notch" in the brace to allow for clearance for the amp.
Brian Bunge
RAD Home Theater
#3 of 26 OFFLINE   Gerry S
Gerry S
  • 122 posts
Posted December 10 2003 - 12:09 AM
What do you think of mounting it to the "front" where there is no brace? Is there really a "front" to a subwoofer in terms of placement of the sub?
#4 of 26 OFFLINE   Brian Bunge
Brian Bunge
    Producer
  • 3,719 posts
Posted December 10 2003 - 12:58 AM
Gerry,
It really doesn't matter. You can mount it on any of the vertical surfaces. You may even be able to offset to one side so that it doesn't interfere with any of the bracing.
Brian Bunge
RAD Home Theater
#5 of 26 OFFLINE   Gerry S
Gerry S
  • 122 posts
Posted December 10 2003 - 02:07 PM
One more questions concerning mounting the driver. Should I use some T-Nuts or just go with the coarse drywall screws?
thanks,
Gerry
#6 of 26 OFFLINE   Brian Bunge
Brian Bunge
    Producer
  • 3,719 posts
Posted December 10 2003 - 02:21 PM
I don't like T-nuts since they have a tendancy to break loose from the MDF. So the coarse thread drywall screws would be a better choice, IMHO.
Brian Bunge
RAD Home Theater
#7 of 26 OFFLINE   Gerry S
Gerry S
  • 122 posts
Posted December 14 2003 - 02:26 AM
I am starting to think about the veneering part of the project. I'd like to round over the vertical corners of the cabinet. The router bit I have is a Crapsman bead/corner bit, and I cant seem to get it to work without a bead. The larger bearing (the one I think I need to use) doesnt have a slinger washer so I cant get it centered.
Anyways I am thinking about buying a new roundover bit. Since I am finishing with 10 mil paperback, are there any suggestions for which size roundover bit to use?
Thanks.
#8 of 26 OFFLINE   Dean-P
Dean-P
  • 134 posts
Posted December 14 2003 - 02:45 AM
3/4" roundover...
Yamaha RX-V730(Pre/Pro)
Rotel RB-956AX (L/C/R)
LG DV7832NXC
Athena AS-B2s (fronts & rears)
Athena AS-C1JVC AV32D20195L Vented Shiva
#9 of 26 OFFLINE   Michael Hartwig
Michael Hartwig
  • 56 posts
Posted December 14 2003 - 10:33 AM
For my Tempest Octagon sub I made a seperate cabinet for the sub amp to sit in and have it positioned with my other audio gear. You only need speaker wire going to the sub cabinet. As for mounting the sub I always use T-nuts. This gives you the most secure mount. The key to sucessful use is to make sure you install them correctly (drill press facilitates in a true perpendicular mounting hole (miss aligned holes is probably the most common cause for failure); the hole has to be large enough to accept the sleeve; hammer the t-nut in (have a solid surface to hammer on), don't try to suck it in with a bolt.) I use T-nuts frequently in my furniture building projects and have had no problems.
#10 of 26 OFFLINE   Larry Alan
Larry Alan
  • 9 posts
Posted December 14 2003 - 10:46 AM
Brian,
I don't understand why the Tee nuts come loose. If they were mounted on the inside with prongs facing toward the outside, they can't come loose. Do you mean they break the mdf because they are so close to the edge? I was planning on using tee nuts, so your input is greatly appreciated.
Larry Alan
#11 of 26 OFFLINE   Brian Bunge
Brian Bunge
    Producer
  • 3,719 posts
Posted December 15 2003 - 02:04 AM
Larry,
Yes, the T-nut can tear through the MDF; even if it isn't near the edge. I had this happen to me when installing some of the T-nuts for the black chrome spikes that PE sells. I think threaded inserts are a much better solution.
Gerry,
A 1/2"-3/4" roundover will work fine for 10 mil paperbacked veneer.
Brian Bunge
RAD Home Theater
#12 of 26 OFFLINE   Gerry S
Gerry S
  • 122 posts
Posted December 16 2003 - 01:14 PM
The plans call for 3.5" long legs. I did that and then rounded over the corners. Problem is I rounded over the top lip on a couple of legs. So if I trim off 1/8" to clean up my blemish I'll end up with legs that are 3 3/8" long. Problem?
I could always just throw some wood putty on the edge and then round it over again as well. What do you guys think?
I probably sound real anal! I just want this to turn out as clean as possible. Plus I also want a good solid surface to attach the veneer to.
In hindsite, I think if I use a fence on my router table I wont have this problem. Live and learn.
#13 of 26 OFFLINE   Brian Bunge
Brian Bunge
    Producer
  • 3,719 posts
Posted December 16 2003 - 02:03 PM
Gerry,
Not a big deal. You could cut them down to 3" high and still be fine.
Brian Bunge
RAD Home Theater
#14 of 26 OFFLINE   Gerry S
Gerry S
  • 122 posts
Posted December 20 2003 - 01:20 PM
I used wood glue, clamps and brads to construct the cabinet today.
I was curious about using caulk on the inside seams to seal the cabinet. Is this a necessary step for a vented sub, given my construction technique?
Thanks.
#15 of 26 OFFLINE   Brian Bunge
Brian Bunge
    Producer
  • 3,719 posts
Posted December 20 2003 - 02:27 PM
Gerry,
If you have nice tight joints with no gaps and have any squeeze out into the cabinet then using anything on the internal seams really isn't necessary. I used to use silicone all the time when building boxes, but as my abilities improved I moved away from doing this.
Brian Bunge
RAD Home Theater
#16 of 26 OFFLINE   Gerry S
Gerry S
  • 122 posts
Posted December 20 2003 - 02:43 PM
I do have squeeze out which almost looks as if I did caulk it so I'll probably pass on this step.
Thanks.
#17 of 26 OFFLINE   Brian Bunge
Brian Bunge
    Producer
  • 3,719 posts
Posted December 20 2003 - 03:30 PM
Gerry,
No problem. I hope you've taken pics along the way! Posted Image
Brian Bunge
RAD Home Theater
#18 of 26 OFFLINE   Gerry S
Gerry S
  • 122 posts
Posted December 21 2003 - 02:08 AM
Well I am going to start taking some pics today. It's pretty uneventful, except for a tiny screwup on one of the sides.
I'm off to get some finishing supplies: contact cement, wax paper, 6" foam roller, sandpaper, and maybe a new belt sander! Am I forgetting something?
Anyway I have been unsure how to proceed on a couple of things. I want the legs and the cabinet to appear seamless. I have rounded over the legs just as I will the cabinet and intend to mount corner of the leg flush with the corner of the cabinet. That's no big deal. But for the veneer to appear seamless as well (consistent grain pattern), it looks like I will have to mount the legs first, then apply the veneer. This sounds challenging for a first timer. Also, veneering the bottom may be a challenge as I will have to work around the mounted legs. I think I'm up to it, but just wanted to see if anyone has any suggestions, considering my goals. If you think this idea is a recipe for destruction, let me know.
Finally, I am starting to think of which color stains or dye to use. I am using red oak veneer. I had thought about a high gloss black, but now am also considering trying to match our entertainment center, which is a golden oak. Are there only certain stains I should consider for red oak veneer, or will anything work?
Gerry
#19 of 26 OFFLINE   Brian Bunge
Brian Bunge
    Producer
  • 3,719 posts
Posted December 21 2003 - 12:16 PM
Sounds like you've got everything you need except for maybe a utility knife to cut the veneer. Veneering the legs as you say may be a bit difficult not having veneered before, but it may not be too bad. I'd suggest skipping veneering the bottom and just painting it black. Or you could veneer the bottom, attach the legs, and then veneer the rest of the enclosure.
Check Minwax and see if they have a golden oak stain. Their is a Honey Maple gel stain that might be similar. I'd be sure to wait a few days after veneering before staining to make sure you've got good adhesion.
Brian Bunge
RAD Home Theater
#20 of 26 OFFLINE   Gerry S
Gerry S
  • 122 posts
Posted December 23 2003 - 12:43 PM
Message Deleted
