Jump to content
Subwoofer calibration
  • Please log in to reply
12 replies to this topic
#1 of 13 OFFLINE   Eric_AP
Eric_AP
  • 74 posts
Posted November 17 2003 - 01:49 AM
I know the theory and what you are "supposed" to do, but it seems like I can't bring myself to lower my sub's level so that it reads the same as my other speakers on the spl meter. I have my sub at between 6-7 db higher than my other speakers (using the SPL meter). This is both on my receiver's internal test tones, and using audio calibration DVDs. When I lower it much below that, I just don't seem to get the oomph from my sub that I like. I also don't feel that my sub is overpowering the DVD soundtracks, where I have it right now. My current setting seems to be a good compromise between a nice sub impact, and blending of the soundtrack. The one thing that bothers me is that I don't feel the room shaking in movie theaters. Yet I hear alot of people talking about the room shaking in their home theater (and mine does too on certain explosions and where you might expect to feel shaking -- not the whole time). Is this because most subs are cranked too high at home? Is 6-7 db too high? Why don't the walls/floor shake in the movie theater? And I'm talking new multi-plexes with supposedly the latest and greatest in sound set-ups. So where do most of you calibrate your sub relative to your other speakers? Am I nuts for having it 6-7 db higher? In case it matters in your analysis, I have a Paradigm PDR-10 sub. My receiver would be playing DVDs at reference level at a reading of 82 on the main volume display. I play DVDs generally at about 67 (which is plenty loud). My receiver is an Onkyo TX-sr701.
#2 of 13 OFFLINE   Robert AG
Robert AG
  • 129 posts
Posted November 17 2003 - 04:51 AM
The THX gods are not going to strike you down if you like to run your subwoofer "hot". If it sounds better to you this way, by all means do it. I have a room that is calibrated to exactly match the levels on a movie dubbing stage since I do mixes of music that end up there for final mixing. But when watching movies for myself, I crank the subs by about 5db for the extra rattling of the walls - I just like bass. I spend a good deal of my time on dubbing stages where the movies are mixed, and can tell you that the subs don't rattle the walls there either. The "rattling of the walls" you hear in some home theaters are caused by two things. One is that the relative size of the subwoofers relative to the room which they are in with a home environment is different in a home than a movie theater (or dubbing stage). There is more subwoofer to room size in a home. To equal this ratio in a theater would mean more subwoofers than would be practical in a lot of installations, and thus cost. The other reason is that in a home, the subs are simply more likely to be cranked beyond the level they would be if calibrated critically to reference level. In a movie theater, they are more likely to be calibrated to reference level. The ideal method to properly calibrate a system is to use spectrum analysis and a calibrated microphone along with full bandwidth pink noise. In a home, the test tones (which are not full range pink noise except for the "Avia" test DVD disc) suffice quite nicely.
#3 of 13 OFFLINE   WayneO
WayneO
  • 625 posts
Posted November 17 2003 - 05:05 AM
There is also a lot less things to rattle in a movie theater than at home. You got shelves and knick-knacks and all that jazz that vibrate so easy. If you could tie everything down you'd probably find the bass response "tighter" as well.
If the best advice is "listen for yourself", then why offer your opinion?
#4 of 13 OFFLINE   MarkyM
MarkyM
  • 27 posts
Posted November 17 2003 - 05:12 AM
My SVS 25-31PCi runs about 3 db hot on the meter but if you
factor in the 3db correction then it runs about 6db hot, which is the way I like it......Posted Image Posted Image Posted Image
Eliab/Dave Abrams calibrated 47" Panny
Yamaha,NAD,Toshiba "in the rack"
Paradigm all around
SVS on the floor
#5 of 13 OFFLINE   ChuckRG
ChuckRG
  • 44 posts
Posted November 17 2003 - 05:27 AM
Assuming you are using a RS meter for measurement, then a 2 to 3 db increase of the subs over the mains is actually setting the subs equal to the main (given the RS documented calibration issues for low frequencies). The reason walls move in your HT is due to compressing the air in the room and hence moving the walls. I have 4 subs (12 drivers) so my room moves a bunch with explosions even if the level is set below the mains -- it's all about moving air. The reason walls don't move in your local cinema is that the woofer driver area to the cubic feet of the theater is miniscule compared to your HT.
#6 of 13 OFFLINE   ChuckRG
ChuckRG
  • 44 posts
Posted November 17 2003 - 05:31 AM
My bad: I said that wrong. You have to add 2db to 3db to the RS meter reading to have it be correct, so you would set the subs 2 to 3 db (according to the RS) BELOW the mains. Sorry.
#7 of 13 OFFLINE   Eric_AP
Eric_AP
  • 74 posts
Posted November 17 2003 - 05:33 AM
[quote] Assuming you are using a RS meter for measurement, then a 2 to 3 db increase of the subs over the mains is actually setting the subs equal to the main (given the RS documented calibration issues for low frequencies). [quote]
Don't you have it backwards? I thought the RS meter read 2 to 3 db higher? So if it reads 3 higher on the sub, it was actually 6 db higher in reality?
I thought I read that due to the 3 db difference with the RS meter, you should (if you want to be technically accurate), actually have the meter read 3 db lower on your sub (compared to the mains) -- to have the sub really be equal to the mains?
Or do I have it backwards?
Never mind -- just saw your correction.
#8 of 13 OFFLINE   Wayne A. Pflughaupt
Wayne A. Pflughaupt
    Producer
  • 5,937 posts
  • Real Name:Wayne
  • LocationKaty, TX
Posted November 17 2003 - 05:55 AM
Eric,
It’s not unusual to have to boost the sub in a home theater in order for it to sound right. The fact is, the smaller the room the more boost is needed.
If you’re feeling brave you might want to slog through the information at this thread.
Wayne A. Pflughaupt
My Equipment List
“A nice mid-fi system,” according to an audiophile acquaintance.
My Tech / DIY Articles and Reviews
#9 of 13 OFFLINE   JohnnyG
JohnnyG
  • 1,523 posts
Posted November 17 2003 - 07:24 AM
I've pretty much given up on the SPL meter entirely on my home system. DVE gives one result, AVIA another and the built-in test tones something else entirely. None of them are even close to a consensus. The receiver is an H/K AVR8000 (THX Ultra) and part of the THX certification process is supposed to be the accuracy of the built-in test tones. THX says to use these tones exclusively for setting the speaker levels, but the bass is off the charts if I do this.
#10 of 13 OFFLINE   Wayne A. Pflughaupt
Wayne A. Pflughaupt
    Producer
  • 5,937 posts
  • Real Name:Wayne
  • LocationKaty, TX
Posted November 17 2003 - 08:32 AM
[quote] I've pretty much given up on the SPL meter entirely on my home system. DVE gives one result, AVIA another and the built-in test tones something else entirely. None of them are even close to a consensus. [quote] The reason is that they are unable to take into account the size of the room – it would be impossible for them to do that. The setting will be less for a 6000 cubic ft. open-styled living area than it will for say, a converted one-car garage.
You’ve got the right idea, Johnny: The discs are a good starting point, but for the final adjustment, use your ear.
Wayne A. Pflughaupt
My Equipment List
#11 of 13 OFFLINE   JohnnyG
JohnnyG
  • 1,523 posts
Posted November 18 2003 - 07:16 AM
Wayne, I ran all those tests in exactly the same room - even one after the other. I just don't get it! My gut feeling is that it has something to do with actual LFE channel information. AVIAs tests do not use the LFE channel - just low bass in the main channels that will be crossed-over to the sub. The H/Ks test tones do use the LFE channel, and I suspect DVE does too. There is one AVIA test with real LFE channel, but that's always measured -10dB for me. I've seen those results on several different H/K receivers, and a Panasonic model too.
#12 of 13 OFFLINE   Edward J M
Edward J M
  • 2,031 posts
Posted November 18 2003 - 07:37 AM
The RS meter reads LOW in the bass region. It is C-Weighted and there are correction factors for the C-Weighted curve (the equation is log based and rather complex). The RS meter also introduces its own additional error (beyond the C-weighted correction factor) at extremely low frequencies. This has led to the development of "RS correction factors", which include both the correction for the C-Weighted curve, and also correction for the meter error. Anyway, if you are running the sub 6-7 dB hot on the meter for the sub calibration tone, that is really about 8-9 dB hot since the meter reads about 2 dB low on the typical rumble test tone. If you like the sub that hot, I say FINE. As long as you aren't stressing it or bottoming, go with what makes YOU happy. Ed
Ed Mullen
Director - Technology and Customer Relations
SVS
www.svsound.com
"What we do in life, echoes in eternity."
#13 of 13 OFFLINE   Eric_AP
Eric_AP
  • 74 posts
Posted November 18 2003 - 09:15 AM
[quote] If you like the sub that hot, I say FINE. As long as you aren't stressing it or bottoming, go with what makes YOU happy. [quote]
There is definitely no stress or bottoming out on my sub (perhaps since I don't play at reference level). And I have given it rigorous work-out material -- i.e, Terminator 3; Lord of the Rings (FOTR) -- Extended Edition; Star Wars (Attack of the Clones); U-571, etc.
Perhaps my level that I play DVDs is why it sounds better (to my ears) hot. I play about 15 db below reference level.
The sub gain knob is at a little past 11 o'clock. So the gain is not even half way.
It just sounds too low -- I'm sure below what the director intended (based on movie theater experience), if it is set to match my mains. Perhaps it is the room acoustics too?
