Burning Surround sound demo's on CD-RW (1 Viewer)
NathanP
Hey,
I downloaded a bunch of surround sound demo files to test my HT, but when I use the cd burning programs (Nero and some Sony thing) I get this: "This File is not in the proper 44.1 KHz, 16 Bit, stereo format"
Is there anything I can download that will let me burn them onto a cd?
Thanks..
Nathan
MichaelPe
I've never had problems buring AC3/DTS-encoded WAV files with "Adaptec Easy CD Creator". I know it's not as good as Nero, but it does the job.
DaveF
Catfisch Cinema
Dave
The files you downloaded are mp3 format; it sounds like your burner program requires wav files (uncompressed audio files). You probably need to convert the mp3 files to wav files.
NathanP
I don't think that's the prob.. see, I always burn with mp3's and it usually doesn't give me any trouble..
But I'll convert em' to wav files and see what happens.
Nathan
acinstallation715
