Jump to content
my Art home work due tommorow, what do you think?
  • Please log in to reply
6 replies to this topic
#1 of 7 OFFLINE   Myo K
Myo K
  • 189 posts
Posted October 12 2003 - 04:33 PM
its a pastel drawing i had to do for my drawing class, the assignment required us to draw a picture that consisted of 2/3rds warm colors and 1/3rd cool colors.
ill be turning it in tommorow sicne ive never used pastel until just a few days ago, mainly with this project,
the image consists of 3 images of the same drawing at different steps.
the final example will be the version im turning in tommorow, im kinda nervous about it
any input possibly comments or constructive criticsm would be apprciated, and if there are other fellow artist here id love to see some work of others Posted Image
i chose this subject because hes currently a pop icon at the moment, so i thought he'd be a good subject to draw.
Posted Image
#2 of 7 OFFLINE   Khoa Tran
Khoa Tran
  • 569 posts
Posted October 12 2003 - 05:06 PM
very nice, is that al pacino?
#3 of 7 OFFLINE   Myo K
Myo K
  • 189 posts
Posted October 12 2003 - 05:09 PM
yes! yay someone guessed it, its actually scar face, sorry for the bad pictures, i had to use my webcam :/
#4 of 7 OFFLINE   David Williams
David Williams
  • 2,290 posts
Posted October 12 2003 - 05:44 PM
Myo, I like it! Posted Image
It's hard to tell from the images, but the 2nd, warmer, picture looks more 'Pacino-ish' than the final product, but regardless, they definitely say 'Al Pacino'. I think you got the balance of the requirements just about right (maybe a smidge more warm, but it's hard to tell).
"Only two things are infinite––the universe and human stupidity, and I'm not so sure about the universe." ––Albert Einstein
#5 of 7 OFFLINE   Jason_Els
Jason_Els
  • 1,096 posts
Posted October 12 2003 - 05:49 PM
This is the first time you've used pastels?? Wow! Posted Image
Such a difficult medium and you've used it very well. Congratulations!
For beauty is only a step removed from a burning terror we barely sustain, and we worship it for the graceful sublimity with which it disdains to consume us. - Rainer Maria Rilke
My DVD Collection
#6 of 7 OFFLINE   Myo K
Myo K
  • 189 posts
Posted October 12 2003 - 06:15 PM
your not kidding. i hate pastel, i cant get any detail from it, and i had multiple fits of frustration, i would think i got the colors down perfectly and the flesh tones nice a lively. Then i spray the fixatif on it for preservation and the entire drawing turns redish brown. i had to recolor and respray multiple times before i figured out the frustrating learning curve. i hate this medium. lol
#7 of 7 OFFLINE   Jason_Els
Jason_Els
  • 1,096 posts
Posted October 12 2003 - 07:45 PM
Don't despair! Pastels are a lush medium with incomparable texture and an ability to convey perspective better than oil. The quality of the color is luminous and pastels convey light better than anything. Mastery is very difficult but the rewards are very high. If you need inspiration take a look at the work of Degas or Renoir done in pastels. It's a medium, once dismissed as an affectation of the old world artists, that's gaining in popularity and appreciation. My suggestion is to play with the reglettes and just use them in any which way to get a feel for them. Try drawing in different manners with them and smear them around. Use brushes, sponges, and tissues to test the different effects. Just look at the colors and try to apprehend their depth and quality. With familiarity you will gain confidence and skill. Fixatives are a problem no matter what you do. Only thing you can do is to plan by making a test sheet with smears of all the different regelettes and then spray each sheet with the fixative to see what the resultant color change is. Use that as your key in future work. Try different fixatives. Some artists find cheap, sticky hairspray suits them just fine (don't use the ones with oil in them). In each case of course, make a test sheet. Good luck and I hope you will continue with pastels. A very old friend of my father's is an artist who has just, at age 78, started working in pastels. Already his technique is impressive but he's used watercolor extensively in the past. What's interesting is that he says using pastels have taught him how to be a better painter in oils and watercolors!
My DVD Collection
