Jump to content
Need some help.
4 replies to this topic
#1 of 5 OFFLINE   HowardPM
HowardPM
  • 38 posts
Posted October 12 2003 - 07:10 AM
I finally decided to use my rec. like your suppose to. So I connected the Component Cables From the HDTV cable box to the TV IN on the receiver, then component Cables from the Reciever (Monitor Out) to the TV. Now when I turn on the TV, the screen is all screwed up. kinda like I'm seeing 3 parts of the show in random spots and they moving all around.
If I plug the Components directly from the Cable box to the TV it looks fine. Any suggestions?
By the way I'll have many more questions once I get this working.
Howard
#2 of 5 OFFLINE   Glenn Overholt
Glenn Overholt
    Producer
  • 4,207 posts
Posted October 12 2003 - 10:05 AM
Hi there! The 3 component cables from the CATV box must go into a component 'in' on your receiver. I think you plugged them into the L/R audio and yellow composite sockets.
Glenn
#3 of 5 OFFLINE   HowardPM
HowardPM
  • 38 posts
Posted October 12 2003 - 02:13 PM
I gave up on that I just went directly into the tv. works fine now. Thanks
#4 of 5 OFFLINE   ChrisWiggles
ChrisWiggles
    Producer
  • 4,791 posts
Posted October 14 2003 - 11:43 AM
and to clear things up, too:
You're not *supposed* to go through the receiver at all. Purists would recommend NOT going through the receiver, as it's another set of wires and switching in the path. The only point of going through the receiver is to accomplish video switching and/or simplicity. If it is just as easy for you to go directly to your display (and you don't have more things to connect than inputs on your display), then it's best to go directly to the display, and not through the receiver or any other video switching device(video processors not included, of course).
#5 of 5 OFFLINE   Bob McElfresh
Bob McElfresh
    Producer
  • 5,183 posts
Posted October 14 2003 - 05:53 PM
Also note that just because a receiver has component switching, component does not mean it will handle the higher-frequency HDTV video signals:
Component Video (480i) max frequency: 4 Mhz
Progressive Video (480p) max frequency: 12 mhz
HD Video (1080i) max frequency: 35 mhz
This is why you should go direct from source to TV with a HD system.
if you run out of inputs, there is a "Inexpensive HD Video Switching" thread in the receivers section that discusses several $100-$150 switch box's (and several cheaper alternatives).
