Jump to content
Tu-hds20, Espnhd Problem!
  • Please log in to reply
3 replies to this topic
#1 of 4 OFFLINE   Larry C
Larry C
  • 55 posts
Posted August 30 2003 - 04:54 PM
Hello All I am REALLY hoping one of you can hlp me out!!!!!!! A buddy of mine gave me the Panasonic TU-HDS20. I have it hookup directly to my Samsung TXM3098WHF..........
Problem is this.............
I am getting ALL my HD channels except of espnhd......... For some reason when I put on espnhd I get sound but the picture looks like if I have my componet cables installed wrong. I don't I have checked twice besides all other HD channels come in wonderful.
What is causing this? Anyone know? Please help!!!!!!Posted Image
THANKS
#2 of 4 OFFLINE   David Forbes
David Forbes
  • 621 posts
Posted August 31 2003 - 01:13 PM
ESPN is broadcast in 720p. How do you have the output of your Panny STB set? If you have it set for "native" that means that it will pass 720p in its native format. I'm not familiar with your Samsung set but there are almost no HDTVs outside of front projectors that handle 720p natively. You should switch your Panny STB to 1080i. It's on the front panel of the unit itself. Hope this helps.
David Forbes
Read excerpts from book three in my fantasy series at www.davidforbes.net.
#3 of 4 OFFLINE   Larry C
Larry C
  • 55 posts
Posted August 31 2003 - 05:00 PM
Thanks, I did get it to work!!!!! I did not know that ESPN broadcasted in 720p......
Yes I did switch it from Native to Hybrid which converts 720p to 1080i.
THANKS DAVID!!!!!Posted Image
#4 of 4 OFFLINE   David Forbes
David Forbes
  • 621 posts
Posted September 01 2003 - 12:29 PM
You're quite welcome. HDTV can be very tricky when you're first starting out. Glad you got it working.
David Forbes
