Fixed/Variable Audio Outputs (1 Viewer)
mark laf
Hi.What does a fixed/variable audio outputs mean?Would it be that fixed means that one constant sound level is put out to your receiver and variable means you can control the output to the reciever with the tvs volume control?Thanks..Mark
MTrotter
East Texas
Marc
Yep, that's what it means. If you have a remote for the receiver, I'd recommend the fixed outputs as you might get a little better audio quality.
acinstallation449
