Jump to content
Setting up Subwoofer?
3 replies to this topic
#1 of 4 OFFLINE   zak
zak
    Extra
  • 22 posts
Posted August 26 2003 - 05:53 AM
Hello,
Thanks to everyone who gave input for "Subwoofer Cable" post.
I have wired the sub going out from Yamaha low frequency into sub mono using THX subwoofer cable.
My Test pattern does not include sub and I was wondering how to adjust the sub for optimal movie experience.
The sub has a Min-Max knob and a switch with 60, 80 and 100 as options.
I do have the Radio Shack decibel reader but don't know how to match levels without a Test pattern.
Any DVD's I can use? (I have a fairly large collection)
Or should I adjust it using personal feeling?
The sub is definitely working, I played the scene from Jurassic Park where T-Rex first shows up in rain storm.
Thanks again,
Zak
#2 of 4 OFFLINE   ColinM
ColinM
  • 2,057 posts
Posted August 26 2003 - 06:20 AM
Avia or Video Essentials DVD's are the best. Sound and Vision has a version or two, and are cheaper, possibly as good as the others. (Based on features - all 3 do the same, more or less.)
See if you can rent them...
You call that a knife?
#3 of 4 OFFLINE   scott>sau
scott>sau
  • 190 posts
Posted August 27 2003 - 04:28 PM
Zak, go to www.thx.com and get their demo DVD.
#4 of 4 OFFLINE   brentl
brentl
  • 2,918 posts
Posted August 28 2003 - 03:52 AM
OR grab your copy of Terminator 2 and use the THX optimizer includedPosted Image
That was way too easyPosted Image
Brent
