Jump to content
AA Batteries Charger...
No replies to this topic
#1 of 1 OFFLINE   Martin Fontaine
Martin Fontaine
  • 628 posts
Posted August 25 2003 - 02:15 PM
I have 2 questions.
1. About 6 months ago I bought a digital camera with a charger and batteries. The charger came with 1950mAh cells.
Now recently I bought some new ones (For my portable CD Player, but it's the same type) which are 2100mAh. Will my charger be able to charge them fully? I mean, it says in the manual it takes 4h to charge 4 1950's so if I put 2100's in there, will it just take a little longer or will the charger just stop charging at 1950?
2. I know that those 1h Ultra-Fast charger will make batteries wear out quickly while those 15-20h ones will make your batteries last long. But what is the optimal middle ground? I bought 1300's 3 and a half years ago and they are still working fine because I've been charging them in the supplied charger which took 13h to charge 1300's. Recently, I started using my new charger for them and now they don't really last long enough which is why I bought new ones.
So what is the best compromise? I don't want my batteries to be finished after 10 charge cycles but don't want to wait 20h to charge them.
My DVDs | My Equipment
No OAR = No Sale!
If you don't want black bars, then you don't want DVD!
