Need long subwoofer cable (1 Viewer)
Dave_La
I'm trying to run my sub to the back of my living room approximately 25ft. Where can I buy it that long or can I make it myself using coax cable. If I can, what kind of coax. Thanks.
DarrinH
RG6 coax will work fine.
I have somewhere around a 25' RG6 coax cable that I did myself for my SVS.
No problems at all, just make sure you get the ends crimped on correctly.
Bill Kane
OR just buy the 25-foot RG6 black coax at RadioShak for $7 and add two F-to-RCA adapters for
Mark Rich
Check out one of the Teflon based Belden 89259, 1695a or 1506a
Then either use Canare crimp on connectors or solder on a decent RCA of your choice.
DaleBesh
I like the Monster sub cables for the flexibility, neutral color, and what appears to be very good construction. And an easy cable to snake along walls.
papill6n
